So many choices...
Old Apr 28, 2004 | 12:13 PM
montana70's Avatar
montana70
So many choices...
Hey All. I wanted to get your opinions on my 360-? FE build. I have my block in at the machine shop for .060 bore and cleanup. I have new pistons and 390 rods. The big ? is, since I havn't purchased the crank yet, what is the most optimal for high perf street application? (70 f 100 2WD) Should I just go with the 390 crank or look for something bigger? Anyone's input is greatly appreciated! Eric
Old Apr 28, 2004 | 02:19 PM
Mike G's Avatar
Mike G
Because you already have the pistons and rods, go 390 or upgrade to the 428 crank (410 CI). Of course, surely there is a stroker crank you may want to entertain...
--Mike
Old Apr 28, 2004 | 05:18 PM
montana70's Avatar
montana70
Talking
Thanks! What would I gain with the 428 and what other mod's might I have to consider?
Old Apr 28, 2004 | 05:50 PM
Randyb12's Avatar
Randyb12
you would need new pistons with a 428 crank. Since you already have the pistons and rods just go with the 390 crank.
Old Apr 29, 2004 | 10:44 AM
montana70's Avatar
montana70
Wink
Cool! Thanks!
Old Apr 30, 2004 | 11:12 AM
montana70's Avatar
montana70
O.K. If I'm not mistaken, the rods for a 390-428 are the same. Are the pistons the same? If YOU had the choice, would you go with a 390 crank or a 428 crank, why? I'm looking at a stroker 428 that I might buy if it will work O.K. with my 390 rods/pistons. Any input is greatly appreciated.
Old Apr 30, 2004 | 05:54 PM
Randyb12's Avatar
Randyb12
428 pistons have a shorter pin height. Pin height is the distance from the top of the piston to the wrist pin center line. They are also 4.13" bore, a 390 is 4.05".
Old May 1, 2004 | 06:18 AM
dinosaurfan's Avatar
dinosaurfan
choices
Montana, it depends on which pistons you already have. Some '390' pistons will work with the 428 crank and lots will not. Can you give us a part number ? And there is cost, in my area you can find a 390 crank for less than 100$. Buying a new 428 crank would cost about 4-500$. DF
