front driveshaft
Old Apr 28, 2004 | 11:30 AM
starboy's Avatar
starboy
front driveshaft
thanks guys. I'm going to have an issue converting my driveshaft, I guess. Does anyone know of a good way to do it? These old trucks are hard to find in a lot of the local wreckers' yards, especially the small-block C6 config.
Old Apr 28, 2004 | 01:16 PM
proeliator's Avatar
proeliator
I'm not sure what your issue is? Yokes? Length? I imagine its just length. Just take your ds to a shop and have them cut and balance it to your specs.
Old Apr 28, 2004 | 04:49 PM
starboy's Avatar
starboy
yoke or spline
yo Pro thanks for the hit. I am taking my dl to a strong shop here in ABQ. Do you know if they can fit a spline assembly on my oem shaft, cut off the yoke?
Old Apr 28, 2004 | 09:25 PM
proeliator's Avatar
proeliator
You'd have to ask the shop you're taking it to. What are you trying to match up?
Old Apr 29, 2004 | 07:49 PM
starboy's Avatar
starboy
The output shaft from the C6 and the front end of the front driveshaft. I spoke to the driveline guy when he did my gearset, but not lately. I don't know why I can't find a stock unit, actually.
Old Apr 29, 2004 | 08:07 PM
Lobuck76's Avatar
Lobuck76
They can change the yoke if yours is worn.
Old Apr 30, 2004 | 01:25 PM
starboy's Avatar
starboy
front yoke
the 4-speed has a yoke output shaft, the C6 uses a spline. The driveshaft needs a new configuration, unless I can find a used one somewhere.
79str8six
Mar 2, 2012 07:01 PM
dansdrumstick
Feb 6, 2012 03:13 AM
Peter Richards
Jul 4, 2009 11:08 AM
CowboyFromHell
Offroad & 4x4
Feb 26, 2009 06:19 PM
Skandocious
Mar 18, 2007 09:08 AM
