Removing driveshaft
Old Mar 17, 2007 | 03:34 PM
Skandocious's Avatar
Skandocious
Removing driveshaft
This afternoon I will be removing the rear driveshaft from my truck to check ujoints and trying to find a vibration in my driveline. I have marked off all of the points on the driveshaft that need be marked and now I am ready to remove it. There are 4 starlike nuts where the driveshaft connects to the rear diff. When trying to unscrew these, they are obviously very tight and the driveshaft rotates then stops when I try to turn the wrench. The truck is in park, is it okay to the wrench against the gears in the transmission like this? It requires quite a bit of force. Also, are there any other words of advice that can be offered about removing the driveshaft?
-Chris
Old Mar 17, 2007 | 04:20 PM
broughy84's Avatar
broughy84
I don't think there would be any difference between wrenching against the park pawl and parking on an incline. The pressure shouldn't hurt the gear, I wouldn't think.
Old Mar 17, 2007 | 04:36 PM
Trickedout420's Avatar
Trickedout420
ill offer you advice, if it was anything like mine this is going to be a 12 pack of beer job because whoever took the shaft off before me over tightened the bolts when putting it back on and i snapped the bolts
Old Mar 17, 2007 | 04:44 PM
Skandocious
Well I soaked the bolts in WD40 for over an hour (couldn't find my liquid wrench) and I still can't get them to budge with the 6 inch handle on my socket wrench. I'm sure that I could break it loose with my cheater bar but I just hate to put that much pressure on the tranny, can anyone confirm that I am going about this correctly? Just wrench the bolts as hard as I can until they break loose.
They also look as though they are right hand threaded as normal, but are these possibly one of the weird left handed threaded bolts?
-Chris
Old Mar 17, 2007 | 04:49 PM
broughy84's Avatar
broughy84
Can you get an impact wrench on them?? It may break the bolts, but they are bolts not studs right? You can replace bolts.
Old Mar 17, 2007 | 04:51 PM
Skandocious
I thought about using the impact wrench but figured that would be more dangerous than wrenching it by hand. I tried slammin' the handle of my wrench with a heavy hammer a few times, wouldn't break loose. Can anyone confirm that an impact gun would be safe to use here?
-Chris
Old Mar 17, 2007 | 05:52 PM
loepke72's Avatar
loepke72
These are the 12-point, 12mm bolts, right? If so, they have threadlocking compound on them, so they will be difficult to remove. You won't damage them using an impact gun or by using a cheater pipe with a ratchet. In fact, I'd be more worried about breaking a ratchet or socket than anything on the truck. I use an impact gun on these all the time at the dealer I work at and never have any problems. In fact, I would recommend the use of an impact gun to make this job easier. Also, be sure to apply some threadlock (Loctite) on the bolt threads when going back together.
Old Mar 17, 2007 | 05:59 PM
Skandocious
Thanks a lot, I got it off with the cheater bar. Driveshaft is now sitting next to my truck. I was going to try taking it for a spin in 4wd, essentially only in front wheel drive with the rear shaft removed, in an effort to try to isolate the vibration I'm having. But when I took the rear shaft off the t-case started to drip fluid, I turned the engine on and put it in drive, and it started spewing quite a bit of fluid when I gave it some gas. People have suggested driving my truck with the rear shaft removed but how could I possibly do this without spray fluid everywhere??
-Chris
Old Mar 17, 2007 | 06:28 PM
ACarbone624's Avatar
ACarbone624
I had to use a piece of pipe on my neighbors 99 F250. I couldn't get enough leverage laying on the ground under the truck with just the ratchet. And when I reinstalled it, I also used the pipe. Worked pretty well...didn't damage anything.
Old Mar 18, 2007 | 02:04 AM
Skandocious
Thanks Carbone, thats what I ended up doing too, seemed to work out fine.
Anyone know how I am supposed to drive my truck in 4wd with the driveshaft removed without spewing fluid everywhere? Is this even possible? I've had several people recommend that I do this, as well as my Ford service manual saying it too.
-Chris
Old Mar 18, 2007 | 09:08 AM
alz's Avatar
alz
Not possible unless you plug that hole somehow. Old slip yoke? I had an old Blazer I could do this to, but it had a solid yoke in it.
wpnaes
Feb 4, 2021 11:00 PM
Mustangking1
Dec 4, 2015 11:30 AM
Cracker289
15
Jan 13, 2014 10:30 PM
BigF350
Mar 8, 2010 11:51 AM
l67cooled
Dec 29, 2009 04:53 PM
