Rough Running, need help please!
Old Apr 27, 2004 | 09:37 PM
83Ford_F150_4x4's Avatar
83Ford_F150_4x4
Question Rough Running, need help please!
Hi Guys,
I have a 83 F150 4x4 with an inline 6, 300. This truck is great!
I had a problem with this truck, it was backfiring and hard starting. So I thought it was the Carb, played with the choke for a week or so till I got stranded. I replace the Carb with a (Tomco) and the plugs, rotor & cap. After all that found out the problem was the ingnition module.
Any way ever since then the truck runs rough lacks power and has even overheated once, not to the point of complete steam. I have tried to set the idle and the mixture with a tach. Played with the timing and still have the same problems. Its even worst when it rains. I have taken the vacuum line off the distrubutor and found no vacuum. So I don't know if this is correct or not.
But before the replaced parts and problem this truck ran fine.
So any help of what to look at would be great.
Thank You
Wayne
Old Apr 27, 2004 | 09:43 PM
King Triton's Avatar
King Triton
Have you changed your fuel filter?If it gets restricted it can lean your motor out which in turn could make it run hotter
And BTW>Welcome to FTE
Old Apr 27, 2004 | 10:11 PM
83Ford_F150_4x4
Hi King Triton,
Yes I did that when I installed the new carb. I really did it twice.
Thank You
Old Apr 27, 2004 | 10:19 PM
King Triton
Well you said that after changing your carb you found out that the ign mod was bad,have you tried the old carb?
Old Apr 27, 2004 | 10:32 PM
83Ford_F150_4x4
Well the old carb was returned for the core charge. I wish I still had it. I keep wondering if the dizzy needs to be replaced.
When I bought this truck last summer, it was pretty much rebuilt, except for a few things. But the other owner took all the emisions out of it. And capped off alot of lines. So I really don't know if all the vacuum lines are there or not. The truck still has the label for them but its hard to tell whats what, by the diagram.
Old Apr 27, 2004 | 10:38 PM
King Triton
Have you got a vacuum guage?
Old Apr 27, 2004 | 10:44 PM
83Ford_F150_4x4
Nope, wish I did, and along with a compression gauge.
Old Apr 27, 2004 | 10:53 PM
King Triton
Just trying to narrow it down for ya,and a vac guage sure would help,have you checked for vac leaks at the baseplate of your carb?
Old Apr 28, 2004 | 01:36 AM
harem Scarem's Avatar
harem Scarem
Similar problem
Hello hows it going,
I had a similar problem on my 1983 F250 and what I found wrong with mine was the carburetor the parts store sold me was the wrong one they sold me a carburetor calibrated for a non-emission application where I needed the emission calibrated one. Once I changed it It ran great.
Since I read your post about the previous owner pulling the emissions off the vehicle he may have changed the carburetor also to a non-emission rated carburetor in the crossover. When you purchased your new carb from the parts store they probably sold you what originally came with the truck which would of had the emissions. Which would of shown that on there computer. When ordering parts. Hope this helps your problem.
Old Apr 28, 2004 | 06:13 AM
83Ford_F150_4x4
I have checked the base plate and found nothing. But I will check to see if there are other leaks some how.
Old Apr 28, 2004 | 06:15 AM
83Ford_F150_4x4
I will check with Napa to see if they have the non-emissions version there. Good Point though.
Thanks
Wayne
Old Apr 30, 2004 | 07:34 PM
83Ford_F150_4x4
Hi All,
Well I tracked down the problem. Seams the person that changed the plugs for me never tighten them up. And also a broken wire was found on # 3.
So all will be well after I set the fuel and idle.
Thanks for the help.
JohnBOV43159
53
Feb 7, 2014 11:11 AM
semocoachworks
Jul 15, 2012 11:02 AM
carova_kevin
Nov 8, 2005 12:10 PM
luvusa
49
Jan 9, 2003 02:55 PM
deondanno
Jul 14, 2002 03:40 PM
