holley carb & vacuum lines
My 351m has a new intake manifold and a holley four-barral carb on it. I was wondering if there are any vacuum diagrams available for this? i bought the truck not running b/c the motor(not origonal) was not completly hooked up(carb, & wiring). There was previously alot of little gadjets that came with the stock setup that im not shore what there purpose was. now im not sure where to plug in what. so far its running alright after changing the vacuum lines around until it ran its best, but it doesn't want to run smooth unless i play with the choke, even after its at normal opperating temp. Im pretty sure the vacuum is the problem, any advice/help is appreciated.
kevin
1980 F-250 4x4
kevin
1980 F-250 4x4
how much of the emissions junk do you have still hooked up? (egr, air pump,ect.)
i scrapped all of mine so the vac lines are minimal. 1 line from dist. to spark port on carb. at the passenger side rear of the manifold mine has a vac "tree" that screws into the manifold. off this tree-1 line to the power brakes and 1 line to the automatic trans. the only vac lines left are for the pcv system. mine runs great like this. could post some pics in my user gallery if you think it would help. or try using the search feature in this group. good luck.
Some times a little help is better than too much, sounds like you have made progress. What condition is the carb in?? If it is of an older era like the one I have on my 351c it might just need to be scrapped, rebuilding is not even an option. You might want to check and make sure you have good manifold vacuum. Sounds like it might be flooding out(floats too High or bad needles and seats) Good Luck
DD
DD
rdvs
01-28-2010 03:53 PM
Narwhal
11-26-2005 08:23 PM
KJKozak2
46
02-10-2005 07:52 AM
