Stock HORN mod!!?!
Old Dec 8, 2004 | 02:04 PM
architectandbuilder's Avatar
architectandbuilder
It consists of the 26" & 29"Hadley's (from a wrecked Freightliner), a 5 gallon tank, a Viair 550C compressor, and solenoids for a semi-truck fan clutch.
The wire you need to access is under the passenger's side battery tray. It is yellow with a green stripe. I also ran 3 lines from that location to a switch under my dash so I can switch back and forth.
As far as capacity, I run my nail guns off of my truck quite a lot now. It is wonderful when your in an area where you cannot easily plug in a compressor.
Hope it helps.
Barrett
Old Oct 25, 2014 | 09:36 PM
dbest313's Avatar
dbest313
I have 05 excursion . Having issues with horn. Have power to fuse. Tested horn works great. Think it's the horn relay. ... can't locate it. PLEASE HELP! !
Old Oct 25, 2014 | 09:52 PM
nmclella's Avatar
nmclella
https://www.ford-trucks.com/forums/1...ion-fixed.html
^ Says to try cleaning the plugs for the horns.
https://www.ford-trucks.com/forums/8...horn-wire.html
^ Describes finding the wires for the horn, both by the battery and behind the fuse panel.
Good luck, hope these point you in some kind of direction.
Old Oct 25, 2014 | 10:06 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Nothing like a ten YEAR old thread revival holy ****.
Old Oct 25, 2014 | 10:17 PM
dbest313's Avatar
dbest313
Ty I'll try that
Old Oct 27, 2014 | 02:08 PM
Apocalypse's Avatar
Apocalypse
Holy crap, did M. Night Shyamalan start this thread?!? I started out reading it thinking "Wow, haven't seen this one yet and never looked at the dates. Get to the end and *BAM* What a twist!!!!!!
Old Oct 30, 2014 | 07:26 PM
Misky6.0's Avatar
Misky6.0
It is halloween after all
Old Oct 30, 2014 | 11:29 PM
CLINT-THE-GREAT's Avatar
CLINT-THE-GREAT
Posting Legend
HAHA this was me too!!! I was waiting on pics of the setup!
-The Great
OldHarley
Dec 16, 2019 02:25 PM
tjcanno
2009 - 2014 F150
May 16, 2015 06:28 PM
Auburn_in
Jan 16, 2013 11:57 AM
Shortlineent
Aug 23, 2009 09:26 PM
jwilson
1983 - 2012 Ranger & B-Series
Oct 3, 2003 11:47 AM
