Aerostar Ford Aerostar
Drive shaft removing
Old Apr 26, 2004 | 03:41 PM
countrydude's Avatar
countrydude
Question Drive shaft removing
I am trying to remove my starter on a 96 AWD, I removed the bolts on the starter and drive shaft, but cannot get the drive shaft to move, I talked to a ford mechanic and he stated to hit the front drive shaft after the bolts are romved, not doing a thing, looking for answers to removing it, so I can replace the starter, thanks
Old Apr 26, 2004 | 04:16 PM
aerocolorado's Avatar
aerocolorado
Sounds like the two flange surfaces are just stuck together. Once the bolts are out, just tap the connection and it should separate. Be sure to mark the flanges beforehand so they will go back the same way.
Sorry to say, there is not sufficient room to actually remove the front shaft, all you can do is push it as far out of the way as you can. To actually drop the shaft, according to the Ford manual, you have to remove the upper u-joint. You can get the starter out with the driveshaft moved out of the way, but it is a VERY close fit. You need to tip the starter upright and pull it down and out. Lots of wiggling involved as I recall.
Old Apr 26, 2004 | 06:12 PM
mwkobe's Avatar
mwkobe
i dont think its the flange i have seen the splines get stuck though
MauleOne
1983 - 2012 Ranger & B-Series
Oct 11, 2014 08:38 AM
powerram50
Feb 7, 2009 03:53 PM
arnold
2004 - 2008 F150
Nov 11, 2007 10:46 PM
bobfl
Feb 21, 2006 07:54 AM
mahsdarf
Aug 17, 2003 08:57 PM
