Aerostar Ford Aerostar
Power steering blues
Old Apr 25, 2004 | 02:06 PM
shel 67's Avatar
shel 67
Unhappy Power steering blues
Help!! I've been trying to get my power steering line (pressure line on rack) to seal. I've gone through 4 teflon seals already and my latest one just failed. I've tried torquing the nut at 17 ft/lbs-22 ft/lbs but to no avail. It usually seals for about a couple of weeks, and then lets go. Sometimes the nut gets loose and I have to re-tighten it, but it seems by then the seal is leaking again. I've been thinking of trying some thread seal on it. Can anyone help ?
Old Apr 25, 2004 | 07:12 PM
lasher's Avatar
lasher
are you getting parts from ford? stuf like this you need ford parts sometime.
check hoses to see if they move when turning left to right and right to left turn.
thats all i know.
Old Apr 26, 2004 | 01:47 AM
JTHill24's Avatar
JTHill24
They also have a o-ring. I myself just wrapped the threads with that white teflon tape that you use to seal water pipes. Haven't had a leak yet.
Old Apr 26, 2004 | 01:56 PM
shel 67's Avatar
shel 67
Unhappy
I did get the parts from a ford dealership, tried the teflon tape, and I just tried the thread sealing compound. I hope it works. I'm beginning to wonder if the mounting area on the rack is out of shape. The rack is new, the previous owner bought it from Canadian tire, also, the power steering line is also new.
Old Apr 26, 2004 | 03:15 PM
lasher's Avatar
lasher
looks like you did it right. i would say that maybe you have a defect in the rack. you probably got a rebuilt and may of got someone elses problem.
Old Apr 26, 2004 | 04:09 PM
aerocolorado's Avatar
aerocolorado
Second the above opinions on the rebuilt rack. I had to return one because the threads for one of the fittings had been cross-threaded at some previous time. Pull those plastic covers before leaving the store and check the condition of the threads as well as checking to see the replacement seals are in the box.
Old Apr 26, 2004 | 06:05 PM
copper_90680's Avatar
copper_90680
Also check inside the hole on the rack. You may have some dirt ot remnants of the previous teflon rings in ther which made it leak in the first place.
Good luck
Old Apr 26, 2004 | 06:54 PM
shel 67's Avatar
shel 67
I checked the condition of the o-ring after I removed the pressure line and found that the o-ring was pressed out of round, indicating a bad connecting flange on the rack. I used some permatex thread sealer and so far the leal seems to have stopped. Thanx for the info!
