clutch problems
Old Aug 24, 2002 | 11:51 PM
myst's Avatar
myst
clutch problems
i was driving down the road and pushed in the clutch to change gears and the clutch went to the floor and just stayed there i had to reach down there with my hand to make it come back up.it is a 99 PSD and i just had a clutch put in it about a month ago. my friend thinks it might be the slave cylinder. Any suggestions??
Old Aug 25, 2002 | 02:45 PM
xcopterdoc's Avatar
xcopterdoc
clutch problems
Could be either the master cylinder or the slave cylinder. Check your fluid level in the master cylinder. If it is empty, refill, try to pump it up and look for a leak. Whoever did your clutch job may have caused a leak in the line or at the slave cylinder.
Old Aug 25, 2002 | 02:46 PM
powerstroker250's Avatar
powerstroker250
clutch problems
You could have lost the hydraulic system. I had the hydraulic system and pedal assembly replaced under warranty under TSB 99-1-6 last year.
Les
Old Aug 25, 2002 | 07:00 PM
myst's Avatar
myst
clutch problems
I have fluid in the master cylinder.
Old Aug 25, 2002 | 08:02 PM
mr clutch's Avatar
mr clutch
clutch problems
Only 2 things cause your problem, hydraulics and a broken clutch fork. When you had your clutch replaced, did the shop replace the fork. Ford has a updated style fork for all trucks up to 06/00. The original fork was prone to collapse.
Old Aug 25, 2002 | 08:30 PM
myst's Avatar
myst
clutch problems
I do not know if he replaced the fork or not i am going to call him in the morning and ask him.
Old Aug 25, 2002 | 08:42 PM
StanleyZ's Avatar
StanleyZ
clutch problems
maxum96
Nov 17, 2016 07:01 PM
53fordman1
Jul 28, 2016 12:01 AM
53fordman1
Jul 26, 2016 12:18 AM
Frantz
Aug 15, 2015 01:11 PM
John_1953
May 17, 2007 06:09 PM
