Epoxy Primer over Zero Rust?
Old Apr 26, 2004 | 11:45 AM
pshadwick's Avatar
pshadwick
Question Epoxy Primer over Zero Rust?
I have stripped my fenders to bare metal, inside and out.
I plan on painting them with epoxy primer.
Would I be better to paint the inside/wheelwell with Zero Rust?
Would there then be any point in applying the epoxy primer?
I also want to put on an undercoating such as the rattle can rubberized undercoating, or a spray on truck bed liner. Would these go over the Zero Rust or Epoxy OK?
Thanks...
Old May 3, 2004 | 08:55 AM
pshadwick's Avatar
pshadwick
anyone????
Old May 3, 2004 | 12:24 PM
Aekisu's Avatar
Aekisu
<cr>
Assuming your car will be a driver and not a trailer queen...
Epoxy on the outside. Zero Rust on the inside. My ZR rep says the closer ZR is to the metal, the better it works. While it wouldn't hurt to apply ZR over the top of epoxy, you could be defeating some of the qualities of ZR.
I don't use rattle can undercoating. I've been total that after awhile, it cracks and actually leads to rusting.
underthebridgejim
41
Aug 4, 2016 07:13 PM
Aekisu
Paint & Bodywork
Mar 30, 2006 11:58 PM
Chevythunder7578
Paint & Bodywork
Jul 24, 2004 09:21 AM
pipercub
Paint & Bodywork
Jul 2, 2004 10:23 AM
green53
Paint & Bodywork
May 7, 2004 01:12 PM
