Steering Noise
Old Jun 9, 2004 | 01:17 PM
lmadore's Avatar
lmadore
I've even had new pumps that moaned. Just about every older ford truck I've heard running will moan a bit when you turn the wheel.
Do check for air in the system. You could even be syphoning air into the system if there is a leak in the lines.
Chilton's manual details how to refill a system after a new pump install. Follow it to the letter and that may resolve the problem.
Any difficulty turning the wheel?
Old Jun 9, 2004 | 03:18 PM
Nightrain's Avatar
Nightrain
Yeah, quite a bit once it starts chipring or squealing. I'm not talking about that simple moan of the pump turning it around. I'm talking about that high-pitched chirp or squeal. That gets on my nerves. Once it does it, the wheel doesn't want to move. This only happens at idle while I'm sitting still. It's never done it going down the road. The belt is slipping. I've noticed that. But, is the pump locking up or do I just need to replace and retighten the belt?
Thanks.
Nightrain
Old Jun 9, 2004 | 03:23 PM
fai4g63's Avatar
fai4g63
I think your belt just needs to be adjusted or replaced. When your not moving the P/S pump takes alot of power to turn the front wheels.
Old Jun 9, 2004 | 03:28 PM
Nightrain's Avatar
Nightrain
Thanks. I'll check into it this weekend. I know that it has plenty of fluid. I've checked it about a dozen times since I bought this truck lol.
Nightrain
Old Jun 9, 2004 | 04:23 PM
KenB's Avatar
KenB
Details, details, details, . . . . . . .
If you know the belt is slipping, don't go any further until that problem is resolved.
BTW- Observing proper belt tension is a good thing to do. Don't tighten till it's like a steel rod, you'll wear bearing prematurely at the least.
Having "plenty of fluid" may not be enough. Get a Haynes or Chilton's manual, read-up on air bleeding the system.
Old Jun 9, 2004 | 08:45 PM
Nightrain's Avatar
Nightrain
Right on KenB. I should have tightened it a long time ago. I'll get a new belt this weekend and get it on there. To be honest with you, the only reason that I haven't done it yet is because it's a gald-darn pain!! lol.
Nightrain
luck2b
Jul 16, 2011 11:19 AM
399exp
Sep 29, 2009 07:22 AM
mrmootsie
Jan 28, 2006 06:49 PM
bremen242
1997 - 2003 F150
Nov 6, 2005 09:32 AM
Antelope V-10
Nov 28, 2004 06:39 PM
