'01 Stroker Power Steering Issue
Old Apr 25, 2004 | 10:12 PM
4rehauler's Avatar
4rehauler
Has anyone with a Powerstroke experienced a problem with the power steering not working when the truck is stopped and the brake is applied?
I've owned my truck since new and it has always done this, but at 37k miles it began having the same problem when stopped even with no brake applied.
My local Ford dealer has replaced every component in the steering including: power steering pump, steering box, and brake booster despite telling me that this issue was normal. After changing the compents at 37k miles it went back to only having the problem with the brakes applied. Now, at 40k miles it has gone back to no power steering function when the truck is stopped. The dealer says that the problem with the brakes applied is normal, and they say that there is nothing they can do to fix it.
Has anyone else had this problem? Are there any fixes? Aftermarket?
Any input is welcome.
Thanks.
Old Apr 25, 2004 | 10:29 PM
wlihntr's Avatar
wlihntr
i have an early 2001, build date 08/00 and have none of the problems you described, that is pretty odd
Old Apr 25, 2004 | 11:53 PM
WeWeld's Avatar
WeWeld
One of the guys at work has the same problem with his 2000 I replaced everything and it still does it. We were thinking of putting on a smaller pulley on the pump because if we speed up the engine the steering works OK. But we sold the truck and the new owner is picking it up on monday. There was a lot of talk on the diesel stop about it.
GENE
Old Apr 26, 2004 | 12:21 AM
Hossy's Avatar
Hossy
Search for power steering problems there threads on it. Mine 01, my buddies 01, and a buddies from works 00, all do the same thing. A ford tech said its because the hydro boost takes away from the steering pressure when the brakes are applied, i think its BS though.
Old Apr 26, 2004 | 08:27 AM
Ggg6's Avatar
Ggg6
Hossy you were given correct info. The power brakes work off of hydraulic pressure (hydro boost brakes) as opposed to vacuum assisted brakes like cars use. The pump could be getting weak, they have had some go bad early.
Old Apr 26, 2004 | 02:02 PM
Hossy's Avatar
Hossy
Ggg6,are there any aftermarket upgrades to reduce or eliminate this problem? It gets aggravteing when trying to back up a trailer. Thanks.
Old Apr 26, 2004 | 05:06 PM
JMorton's Avatar
JMorton
Per Ford:
1999-2004 SUPER DUTY F-SERIES/EXCURSION - HIGH STEERING EFFORT
SOME 1999-2004 SUPER DUTY F-SERIES AND 2000-2004 EXCURSION VEHICLES MAY EXHIBIT INCREASED STEERING EFFORTS AT VERY LOW SPEEDS OR WHEN STOPPED WITH THE BRAKES APPLIED. CUSTOMERS MAY PERCEIVE THIS AS HIGH STEERING EFFORT. PLEASE REFER TO WORKSHOP MANUAL SECTION 211-00 FOR STEERING WHEEL TURNING RESISTANCE SPECIFICATIONS. INCREASED STEERING EFFORT AT LOW SPEED OR WHILE STOPPED IS A NORMAL CONDITION WITH HYDROBOOST OR VACUUM OPERATED BRAKES, THEREFORE NO SERVICE ACTION SHOULD BE TAKEN.
Sounds normal to me. Sorry.
Old Apr 26, 2004 | 06:56 PM
johnsdiesel's Avatar
johnsdiesel
Sounds normal to me too. I don't turn the wheel when stopped because of the added stress on the pump. Remember, the PSD weights more than 1K lbs.
Old Jun 10, 2004 | 08:36 AM
Rednels's Avatar
Rednels
Has anyone found a smaller aftermarket pully to fix this problem?
Old Jun 10, 2004 | 09:40 AM
eckart's Avatar
eckart
Don't know if theres one for a psd but there are companys that make pumps with more presure down low. Alot of the rock crawler guys use these. I'll look in some back issuse of 4by mags. One of them was upgrading the steering on their ultimate superduty.
Old Jun 10, 2004 | 10:00 AM
Rednels's Avatar
Rednels
I was hoping for a relativly cheap option to just speed the pump up a bit at idle and low speed.
Old Jun 10, 2004 | 11:10 AM
cgl's Avatar
cgl
You could get a AGR Performance, Ford Super Pump #877257 for $229.
__________________
2002 F-350 XLT 4x4 PSD 6spd SC SB SRW
1990 F-150 Lariat 4x4 I-6 5spd RC SB
---Also in Family---
2003 F-250 XLT FX4 6.0PSD TSA SC SB
2001 F-150 XLT 4x4 5.4 AT SC SB
Old Jun 10, 2004 | 12:36 PM
Rednels's Avatar
Rednels
Thanks CGL. that is exactly what I was looking for.
radsevere
17
Jan 23, 2021 01:48 AM
thenorway
6.7L Power Stroke Diesel
Dec 12, 2012 06:39 PM
quiacato
Feb 28, 2011 08:52 PM
adam42481
Aug 27, 2004 09:53 PM
