Sponsored by: Real Truck
Shock decompressed during tire removal
Old Apr 25, 2004 | 06:05 AM
coachhomer's Avatar
coachhomer
I jacked the truck up and removed the fron left tire and was going to repair it and thought it might be a while. Since I had the truck jacked from the axle, I decided to leave it on stands and put the stand under the left side frame. Well as I lowered the jack, the axle came with it and now my truck is angled on the stands. Did the shock just decompress? How do I fix this? Am I screwed?
Help!
Scott
Old Apr 25, 2004 | 08:57 AM
twoballsleft's Avatar
twoballsleft
Am I missing something here?....just jack up the axle again.
Old Apr 25, 2004 | 09:20 AM
Yeti's Avatar
Yeti
Well, the left side front would be lower, due to not having a wheel on it, but I guess Im not understanding your question.
Like twoballsleft said, "just jack up the axle again"
Hossy's Avatar
Hossy
Whether the shock is under load from the tire on the ground or the axle it shouldnt matter.
Old Apr 25, 2004 | 10:50 AM
RIS's Avatar
RIS
The frame went up with the axle due to the jack. "OK" So then you slid the jack stand under the frame and lowered the axle & frame onto the stand. Now I would guess the stand & frame are higher than it would sit with a tire. ???????????????????
RIS
Old Apr 25, 2004 | 12:29 PM
aldridgec's Avatar
aldridgec
And the other side of the truck, the tire, is sitting on the ground. So that tire is pushing up, and the left side is hanging so it would be lower.
Old Apr 25, 2004 | 12:39 PM
Greg250's Avatar
Greg250
Just put the tire back on let the truck down and thats all you have to do.
Old Apr 25, 2004 | 03:13 PM
FF-Paramedic's Avatar
FF-Paramedic
Saw over on another site where he posted the same info that all ended up well.
The way I gather it was after he removed the tire when he put the stand under the frame on the left side and lowered the jack that was under the axle, the suspension allowed the left side of the axle to hang lower than the right side (shock went to full expansion).
When he put the jack back under the axle and jacked up the axle to re-install the tire and get the stand out from under the frame the shock compressed to the length it should be and all was ok!
Old Apr 25, 2004 | 08:34 PM
coachhomer's Avatar
coachhomer
Yea guys, that is correct. thanks for the help. something just didn't seem right but once i got the tire back on and lowered the truck, it sat level. sorry for the confusion.
scott
Old Apr 26, 2004 | 04:28 AM
Monsta's Avatar
Monsta
Sit. Stay.
Well now that you know everything is okay...it was the spring that went back to its unloaded position. The shock had nothing to do with it.
