More power?
Old Apr 24, 2004 | 09:08 PM
johnsdiesel's Avatar
johnsdiesel
Originally Posted by ForemanES
Is Tymar a better filter than my K&N?
In my opinion, and the opinion of most, yes. The only way to decrease restriction over the same surface area is to decrease filtration. It doesn't matter whether it's a paper, cotton, or foam filter, physics 101 says that the material has to be more porous to allow more airflow over the same surface. Although K&N offers a pre-cleaner, that defeats the purpose of using an aftermarket filter by adding to restriction. The Tymar filter gives you the best of both worlds, decreased restriction and good filtration. It does this by using a huge paper element as seen here:
http://community.webshots.com/photo/...36219971hAOAqJ
I paid $109 for my intake and replacement filters can be found for as cheap as $19. If you want information on where to order it I can email it to you (not supposed to post emails or phone numbers of non-paying advertisers).
Old Apr 24, 2004 | 09:10 PM
ForemanES's Avatar
ForemanES
I dont want any trouble!!! So the Tymar uses paper elements?
Old Apr 24, 2004 | 09:14 PM
johnsdiesel
Yes. If you want various opinions do a search on "Tymar" or "air intake." There's almost always at least 1-2 current threads on air intakes with varying opinions.
Old Apr 24, 2004 | 09:18 PM
ForemanES's Avatar
ForemanES
We went off course a little. Is the Banks powerpack, or any system for that matter worth their hefty price? Did you actually see gains in mpg?
Old Apr 24, 2004 | 09:41 PM
bender97f250's Avatar
bender97f250
The prices of Banks are the only negative.If I was to drive conservative I see a slight gain in mpg.The problem I found is I cant keep my foot out of it and my mpg gets worse.Once you install a kit,you will think you are driving another truck.
JB78f150
Oct 23, 2011 08:29 AM
Green Griffin 420
May 12, 2011 04:13 PM
papaducky
Oct 22, 2005 08:53 PM
f-4x4
Aug 15, 2005 09:54 AM
jwtaylor
23
Dec 6, 2003 01:35 PM
