Sponsored by: Auxito
A/C works then it doesn't
Old Apr 24, 2004 | 01:30 AM
CPerry's Avatar
CPerry
Sometimes when I turn on the air conditioner it works fine and sometimes it doesn't work at all. It blows air but not cold air. Any ideas as to what's wrong?
Old Apr 24, 2004 | 05:42 AM
HomerWinzlow's Avatar
HomerWinzlow
When its not working, try jumping across the connector at the cycling switch. It could be failing.
Old Apr 24, 2004 | 10:07 PM
CPerry's Avatar
CPerry
What is the cycling switch and where is it?
Old Apr 25, 2004 | 06:57 AM
HomerWinzlow
On the passenger side near the firewall you will find the accumulator tank for the air conditioner, and acrewed onto that tank is the cycling switch. Just unplug it when the ac isnt running with the AC turned on and engine running and with a piece of wire stripped at both ends, jump the two pins inside the wiring plug that you remove from the switch. This bypasses the switch and tells you if the switch is what is preventing the compressor from engaging. If the compressor then engages and the AC gets good and cold you can replace the switch on the tank and see if all is restored to normal. Sometimes those switches will work till they have cycled on a few times and then give out.
Old Apr 25, 2004 | 12:03 PM
CPerry's Avatar
CPerry
Thanks Homer, I'll check it out.
Vinford
6.7L Power Stroke Diesel
Nov 8, 2018 07:21 AM
CaptainMarvel
1997 - 2003 F150
Mar 11, 2015 06:54 PM
taxidriver
Oct 16, 2004 10:18 AM
dthollis
Jul 14, 2003 03:57 PM
iatan
Electrical Systems/Wiring
Feb 6, 2003 11:06 PM
