Sponsored by: Auxito
programming 3 remotes
Old Apr 23, 2004 | 10:46 PM
paul812's Avatar
paul812
has anyone programmed 3 remotes within the 20 seconds allowed? and on the 8th cycle, you have to turn it back to the on position so really you've started the 9th cycle??? just need a bit of advice before my first attempt.
thanks!!...pross [2001 sport 2 x 4]
Old Apr 24, 2004 | 09:28 PM
Racerguy's Avatar
Racerguy
Did you get it figured out yet?
I guess if you think about it, yes you are starting the 9th cycle.
Just turn the key from off to run 8 times, the door locks should cycle, and then hit a button on each remote.
Your owner's manual should have instructions in there for doing it too.
Old Apr 25, 2004 | 09:51 PM
paul812's Avatar
paul812
got it!! took about 3 tries. i think i wasn't doing the 8 cycles fast enough at first.
thanks!.....
Patriot_RAM
Oct 31, 2023 04:16 PM
Number21
Dec 20, 2013 11:22 AM
86F150302
Mar 13, 2009 12:37 AM
jack3
Feb 26, 2004 03:20 PM
