Sponsored by: Real Truck
Programming new remote for 2004 F350
Old Oct 24, 2013 | 09:35 PM
Number21's Avatar
Number21
I just bought a new remote for my 2004 F350, looks like an OEM Ford remote. The seller I got it from on ebay gave me these directions for programming:
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode. (Off is the position where you can remove your key, RUN is the postion just shy of starting your car.)
Within 20 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 4.
Within 20 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 3. for all other remotes.
Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Turn the key on/off 8 times, it does nothing. Tried several times. Anybody know what the problem is here?
Old Oct 24, 2013 | 09:45 PM
05F250DSL's Avatar
05F250DSL
I just did this to mine I assume you do not have a owners manual? You do not turn the key all the way off. Go one click then forward and back not to start and not full lock. You must electronically unlock the doors before you start an close them I believe. Once they cycle hit a bottom on the remote. If you have other remotes you have to do them all at once. You are positive the truck has remote entry? My coworkers 02 xlt also would not go into programming mode.
Old Oct 24, 2013 | 09:47 PM
05F250DSL's Avatar
05F250DSL
If u can't get it I will try tomorrow to get the word for word out of my manual for you.
Old Oct 24, 2013 | 10:18 PM
Number21's Avatar
Number21
Ok, I'll give that a try in a few minutes. No manual...already have another remote though.
Old Oct 25, 2013 | 03:54 AM
Number21's Avatar
Number21
That was it, got it to work. Thanks for the info!
Old Oct 25, 2013 | 05:55 AM
redford's Avatar
redford
FTE Leadership Emeritus
Go to this website
http://www.motorcraftservice.com/
Click on the OWNERS GUIDE link on the left column, then you can select and download a PDF version of your owners manual.
Old Oct 25, 2013 | 05:59 AM
SC_Hoaty's Avatar
SC_Hoaty
The first time I tried it for mine, I had the timing off (forgot if I was too fast or too slow). If you want an electronic copy of the owner's manual (NOT the service manual!) you can download one here - - - > https://owner.ford.com/servlet/Conte...eVehicleLookup
Old Dec 19, 2013 | 12:08 PM
scurling's Avatar
scurling
I realize this is an old post, but I'm having the exact problem with my 2004, F250, I just purchased. A very clean and well kept vehicle. The small dealership could not get the system to go into program mode. After driving home (150 mi) I opened the user manual and tried myself.
Still nothing....after cycling the key 8 times, the system never goes into program mode. the locks do not cycle.. just nothing, other than the normal run-position electronics. I start with the doors unlocked, I cycle the key as shown in the manual
I called the dealer for any ideas. Of course they wanted me to bring it in for them to inspect... min 1 hr. labor.
Does anyone have an ideas what I can try?
Yes, I've install a new bettery, and the dealer looked up the vehicle and SN on the remote and said they ae a match.
Old Dec 19, 2013 | 05:40 PM
SC_Hoaty's Avatar
SC_Hoaty
A few questions:
1) 2004 Ford _______? Dunno if it makes a difference, but it might.
2) Do you have 1 working remote and are trying to program the 2nd, or what?
Until then, try changing the timing of your on-off cycles. Too fast and it won't work, and the same for too slow. I was getting frustrated until I got it to work for me.
Old Dec 20, 2013 | 09:43 AM
scurling's Avatar
scurling
Sorry for the lack of info. I have a 2004, F250, 4x4, Crew Cab. I am trying to get the single, original, remote keyless entry working.
Thanks, I'll try some more. I have tried quick and slow key cycling, but I understand the timeing may be the issue.
Old Dec 20, 2013 | 10:10 AM
SC_Hoaty's Avatar
SC_Hoaty
Strange that the original remote doesn't work. I had bought a replacement (truck only had one, wanted a second) off eBay for like $20. But if you can't get the truck to go to program mode, that would do no good.
I checked, and your year and my year have a different sequence to go through. I found yours at 2004 F250 Manual on page 80.
Good luck!
Old Dec 20, 2013 | 10:11 AM
SC_Hoaty's Avatar
SC_Hoaty
One other note - for my year it says if you step on the brake, it cancels the whole process.
Not sure if that matters for you, but it might.
Old Dec 20, 2013 | 11:22 AM
scurling's Avatar
scurling
Thanks for the note. I know I've not had my foot onthe brake, but I'll make sure I don't touch it when I try again today.
fgvanwhy
Apr 20, 2018 12:57 PM
lstitt
Australia Chapter
17
Jul 15, 2014 04:25 PM
brandon.edwards
Mar 10, 2014 12:01 AM
300sflyer
Oct 27, 2012 02:41 PM
wanabe2
Mar 27, 2009 07:48 AM
