Sponsored by: Innova
adding speakers? wiring?
Old Apr 23, 2004 | 07:43 PM
ttam31's Avatar
ttam31
Lightbulb adding speakers? wiring?
I am looking to add(not replace) two 6x9 speakerss to my f-150 sound system but i do not know how to wire them can anyome help? Do i need to add a amp? How do i take wires to the new speakers?
Old Apr 23, 2004 | 07:54 PM
mzimmers's Avatar
mzimmers
A couple of questions: are you using the stock head unit? And how many speakers does the truck currently have?
Old Apr 23, 2004 | 07:58 PM
ttam31's Avatar
ttam31
Lightbulb stock head unit?
i dont know what a stock head unit is but the truck currently has 4 speakers adn i want to ad two more
Old Apr 23, 2004 | 08:03 PM
mzimmers's Avatar
mzimmers
Short answer: yeah, you're going to need an amp. How much you're willing to sink into this project will drive the equipment you choose. I'd suggest looking at one of the a/d/s multi-channel amps -- they're small, have clean power and can be had on eBay for not too much $$...
Old Apr 23, 2004 | 08:05 PM
ttam31's Avatar
ttam31
awesome thank you so much do i splice a wire and send it too the amp and then to the speakers or how does that work?
Old Apr 24, 2004 | 03:20 PM
triton_2002's Avatar
triton_2002
It sounds like you're not too familiar with car audio equip., in which case I would suggest to take the truck to a car audio shop and have the amp installed. But if you are the DYI type, here is what you need to do.
1. Go to walmart, best buy or whatever is near you and get an amp installation kit. It has all the wiring for the amp. You will need to run the + power wire staight from the battery and into the cab of the truck. The ground wire needs to be as short a possible and attached to the chassis of the truck (scrape off any paint and add some grease before screwing down)
2. (assuming you have the original Ford stereo) You will need to remove the trim around the stereo and remove the stereo so you can access the wiring.
Here you need to splice into the speaker wires and add a line level converter to hook up your RCA's to feed the amp. Also you need to find a remote turn on wire to turn on the amp.
3. Run your wiring under the door sills back to where you mount the amp and then wire the amp to the 6X9's
Thats the major steps, so if you think you can do it, go for it. There will be more detailed instructions in the amp kit. Oh yea, disconnect the battery before you start! Good luck.
Old Apr 25, 2004 | 08:10 AM
stealth1's Avatar
stealth1
To make your job ALOT easier and sound WAY better may I suggest you get a new headunit. Most,buy not all of them already have rca's on the rear to run to your amp(s). In the long run you'll be glad you did.
Old Apr 25, 2004 | 08:58 PM
ttam31's Avatar
ttam31
what is a headunit?
Old Apr 25, 2004 | 09:43 PM
triton_2002
What's a headunit? Its worse than I thought. A headunit is your radio.
Take it to a shop, tell them what you want and pay the man. You'll avoid some headaches.
Old Apr 27, 2004 | 08:56 PM
ttam31's Avatar
ttam31
I am going to keep my head unit but i also want to add a subwoffer and have found a amp at walmart its is a Virtual Reality Sound Labs 4-Channel Car Amp VRA4.0 How do i wire this in junction with two speakers and a subwofer? How do i know which wire is the speaker wire behind the head unit and how do i attatch it?
Old Apr 27, 2004 | 11:40 PM
dking69's Avatar
dking69
Dude
Your best bet is to take the amp back to wall mart and contact
www.crutchfield.com They should have the schematics and amps you need. If you have no experience with this stuff, it's a great way to hose things up. Pay to have it done if you need to.
Good Luck
Hockeymandan
Sep 27, 2013 08:12 PM
John R. Thomas
Aug 7, 2013 04:13 PM
kereams
Jun 21, 2012 02:23 PM
Bigbruce
18
Feb 3, 2012 02:40 PM
Eric H
Jan 14, 2011 01:48 PM
