Need to know DP Size...
Old Apr 22, 2004 | 08:13 PM
F-250 Super Duty's Avatar
F-250 Super Duty
I want in on the group purchase for the exhaust systems, but what size Downpipe do I need for a 2002 7.3L.....Please answer quick if you know I want to order it tonight. Thanks, Mike
Old Apr 22, 2004 | 08:17 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You can use either the 3.5" or the 4". I think in the long run you'll be happier with the 4".
Old Apr 22, 2004 | 08:20 PM
F-250 Super Duty
Thanks, That's what I wanted to hear!!! That was a quick answer
Does any mod have to be made to the turbo to go to the 4"???
Old Apr 22, 2004 | 08:58 PM
bigdieseldav's Avatar
bigdieseldav
you will have to make one serious modification......... You'll have to modify your RFAPRD...... Right Foot Accelerator pressure Regulator Deally. Its hard to keep your foot out after the exhaust goes in. All the little sounds you've grown to enjoy from the turbo are now pleasantly amplified along with some noticable power to play with. Enjoy.....
Old Apr 22, 2004 | 09:19 PM
cookie88's Avatar
cookie88
FTE Emeritus
Nope, cut the old exhaust off, bolt the new one in.
Old Apr 22, 2004 | 11:53 PM
wlihntr's Avatar
wlihntr
if i remember right you have to move an engine block ground strap, it is right where the pipe comes down, you just unscrew it and screw it back into one of the holes to the outside of the engine block(pretty simple)
Old Apr 23, 2004 | 11:28 AM
cookie88's Avatar
cookie88
FTE Emeritus
Really? I didn't move or alter anything.
Old Apr 23, 2004 | 12:15 PM
wlihntr's Avatar
wlihntr
yea, when i got my system(stainless ats)it had it in the directions, i just said to relocate the bolt out of the way, there were a few tapped holes on the back of the block that the bolt would fit in so you were told to put it one that was out of the way of the downpipe
Grinder Man
Oct 10, 2014 09:35 AM
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
Martin Broll
Computer Chips & Tuners
Apr 6, 2008 12:22 PM
Ford65_F250_NW
Jan 28, 2005 04:18 PM
mustangman66cpe
13
Sep 16, 2003 06:54 AM
