Battery Problems...
Old Apr 22, 2004 | 01:57 PM
ejbaumruk's Avatar
ejbaumruk
Battery Problems...
I left the lights on for a couple days last week, and when I went to start it, it wouldn't start (No surprise there, obviously). I was feeling lucky a few days later and went to try it again, this time it did start-and it's been perfect ever since. Should I be worried that the battery is weak now? Or am I fine? Thanks! -emily
Old Apr 22, 2004 | 02:49 PM
ivanribic's Avatar
ivanribic
No, your battery should be fine unless there are other problems with it (like it's OLD). It's actually a good thing to cycle your battery from time to time though it's never a good idea to do it when you need to get somewhere. If you have any doubts take it by any parts shop (Napa, Schucks, etc) and ask them to do a load test on it.
Old Apr 22, 2004 | 05:27 PM
Ecuri's Avatar
Ecuri
Hmmm, well, here's a little different take:
Car batteries are specially designed for high initial amps applications and shallow discharges. Cars usually start in five to 15 seconds; to start an enginetypically consumes 5%-10% of the battery's capacity. Car batteries should NOT be discharged below 90% state-of-charge.
(From: http://www.pacificpowerbatteries.com...Q/carfaq7.html)
It been a while since I studied on this so forgive me if its not perfect, but my understanding of why batteries don't last forever is that the metal in one plates chemically migrates back and forth between the plates as it charged/dis-charged. The problem is there is no way to get it to re-deposit back on the same place it came from so the battery plates get "bumpy" (I made that up). So when a battery gets deep-discharged a lot of metal moves and doesn't get back to where it belonged and, hence, shorter overall life.
It has been my personal experiece when totally draining a std car battery is that they are never the same again.
Old Apr 22, 2004 | 05:57 PM
Mil1ion's Avatar
Mil1ion
This Battery related thread will be moved to the Electrical forum as it is not a 73-79 Truck Specific.
https://www.ford-trucks.com/forums/s...d.php?t=229258
This could happen with any year truck.
Old Apr 22, 2004 | 07:42 PM
Phinxter's Avatar
Phinxter
Don't forget vibration can quickly kill a battery, and a weak charging system will cause lead sulfate to become crystallized on the plates rendering it junk.
Old Apr 23, 2004 | 03:20 AM
ashvalentine's Avatar
ashvalentine
(Not even Ford-specific!) Had a '78 (other manufacturer) that ate batteries. There was a very very slow drain in the system somewhere and after a coupla months of daily driving the battery would have to be charged. Afterwards the batteries tended not to hold a charge for too awful long. After awhile they'd just die.
ash
['Shoppeth not at Walmart.']
kevinbrown
Electrical Systems/Wiring
Apr 29, 2013 03:02 PM
danw64
Jan 7, 2013 03:18 PM
f350rebel7788
76
Nov 9, 2011 01:29 PM
badfl97
Nov 4, 2011 07:31 PM
flyhound
13
Jul 15, 2005 06:46 PM
