battery light on
Old Nov 4, 2011 | 04:31 PM
badfl97's Avatar
badfl97
battery light on
I have a 2006 explorer v6 the battery light went on today? My wife said it made a clicking noise when trying to start the other day but the battery is pretty new does this mean my alternator is bad?
Thanks
Old Nov 4, 2011 | 05:12 PM
aquanaut20's Avatar
aquanaut20
Not necessarily. You should start by cleaning and greasing all the main battery and ground connections.
When you have them all cleaned, use a MM and check the battery and charge voltage,
  • fully charged battery = 12.4 to 12.6vdc
  • charge voltage = 13.8 to 14.4vdc
.... Philip
Old Nov 4, 2011 | 05:28 PM
badfl97's Avatar
badfl97
She just got home trucks dead I'm getting 11.2v
Old Nov 4, 2011 | 06:01 PM
aquanaut20's Avatar
aquanaut20
That means nothing to me, did you clean the connections??
The battery cannot charge if you have bad circuits....
When you have battery and grounds clean, start truck and check charge rate.... Philip
Old Nov 4, 2011 | 07:31 PM
senix's Avatar
senix
You need to test the charging circuit. Most likely you need to replace both the battery and alternator at this point. My guess is the alternator is the issue.
tractorboy924
2009 - 2014 F150
Jan 15, 2021 09:12 PM
79F-1504x4
53
Mar 3, 2011 01:53 PM
WiseMagic
Oct 15, 2007 02:49 PM
dtony
16
Jan 25, 2006 09:44 PM
mooktank
Nov 11, 2002 03:18 PM
