Head Machining!
Old Apr 21, 2004 | 08:37 PM
FordCardinal's Avatar
FordCardinal
Head Machining!
I have two Ford Motors. One is a 300 6 .The Other is a 400M. I have been told that both motors have heads that can be "shaved" to increase the Comp. Ratio. is this true? And if it is are there any other modifications that need to be done to accomodate the machining?
Thanks
Old Apr 21, 2004 | 10:05 PM
umdstang's Avatar
umdstang
Heads can be shaved to reduce the size of the combustion chamber, therfore increasing compression ratio. Becareful if you have the heads shaved to much you will have to have the intake manifold changed to line up with the head. Also the valvetrain must be checked.
In my opinion this is not a good way to increase compression ratio. Shaving the heads is more for making the head flat for the mounting purpose. I would look for a different head with a smaller combustion chamber, or get some new pistons flattop or domed.
Hope that helps
Brian
Old Apr 23, 2004 | 07:56 AM
jwtaylor's Avatar
jwtaylor
If you use the 400m determine your head combustion chamber volume, and get appropriate pistons to up the compression if thats what you want. As milling the heads on a v-8 could cause head to intake fitment problems, if a certain amount is taken off and they weren't angle milled.
As far as the 300 goes, mill those suckers, this way you can use stock or appropriate stock replacement pistons (that are cheap) and mill the heads for compression, there are no issues as the intake fits directly to one head. Just be sure you know your cc and what the end compression ratio will be, but you knew that. Good luck
Old Apr 23, 2004 | 11:13 PM
FordCardinal
Thanks! I have not been able to find high comp. Pistons for the 400m though. The 300 is going to be milled!
Old Apr 24, 2004 | 05:35 AM
jwtaylor's Avatar
jwtaylor
Give PAW performance a call 818-678-3000 pretty sure they would have access to the pistons you want. Later
Old Apr 24, 2004 | 02:54 PM
dinosaurfan's Avatar
dinosaurfan
of course you can
Cardinal, yes, you can mill the heads on your 400M. Cutting .060 off from the heads is no trouble at all. But it does require you to also mill the sides of the heads ( where the intake bolts on ) the same .060. This will let your intake fit normally. Don't forget you'll also need the .060 shorter pushrods. DF
jvmcc
Jun 11, 2016 06:22 PM
Firemudder
Jun 20, 2012 10:11 AM
Cuda_jim
Aug 4, 2009 12:45 PM
reifwj
Mar 29, 2008 12:11 PM
Dyerstown
Feb 28, 2003 08:41 PM
