NEED HELP: mysterious miss
Old Apr 21, 2004 | 02:05 PM
meck1's Avatar
meck1
I posted this previously on the 300CID forum. Having gotten no answer after a few weeks, I wanted to try again on this larger forum.
My truck is an '87 F250 with the inline 6. It runs great when warmed up but idles terribly. Here is the mysterious part. If I start the engine without touching the gas, it will idle perfectly until warmed up. If I touch the gas, though, it will begin to miss really badly and continue missing until the engine is warm. This engine has all new (or nearly new) sensors, IAC valve, plugs, wires, distributor cap and rotor. I have replaced the EFI plenum gasket, throttle body gasket, and EGR gasket and have cleaned throttle bore, etc. The computer says the truck is fine; it has set no codes.
Does anyone have ANY hint as to what might be going on? This is driving me crazy.
Thanks
Old Apr 21, 2004 | 07:59 PM
Egor's Avatar
Egor
When it's missing, pull your plug wires off the cap one at a time. This will tell you if it's a certain cylinder. If you lift a wire and it doesn't change the way it runs, you'll know where to start. I had an injector go bad on my 351 and it acted like a bad spark plug.
Ryan Weaver
39
Nov 10, 2014 06:14 PM
chaneyb33
Apr 7, 2011 04:18 PM
private-aye-fish
Nov 4, 2007 05:36 PM
meck1
Apr 7, 2006 11:11 AM
meck1
26
Oct 12, 2004 03:33 PM
