Help!! Mysterious miss.
Old Nov 14, 2003 | 08:46 AM
meck1's Avatar
meck1
Mine is an '87 F250 with fuel injection. If I start it up without touching the gas and just let it sit and idle until warm, it will run perfectly. If I even touch the gas once, it immediately starts missing badly and continues doing so until it is warmed up when it, again, runs perfectly.
Does anybody have a clue what is going on here?
Thanks
Old Nov 14, 2003 | 10:38 AM
sicbpguy's Avatar
sicbpguy
Have you tried to pull any codes? That may indicate a problem with some EFI components at different temperatures.
Old Nov 16, 2003 | 02:46 PM
paulfix's Avatar
paulfix
Try using a hair dryer to warm up the TPS prior to starting and during warm up and see if you can get it to misfire with this EFI sensor warmed up 1st
Old Nov 16, 2003 | 03:54 PM
rhetor's Avatar
rhetor
it sounds like you have a dead spot on the TPS sensor at idle, and when you tap the throttle it gets a bad signal, and just goes nuts.
the hair dryer idea was a very good one!
Old Nov 18, 2003 | 02:07 PM
meck1's Avatar
meck1
Thanks for the advice. This miss is not an earth-shaking problem, but it just bugs the devil out of me when something doesn't run right. I'll try what you have suggested as soon as the weather permits. I work on the truck outside, and right now we seem to be into some kind of monsoon season that refuses to let up. I'll let you know what happens.
Thanks
Old Nov 23, 2003 | 04:39 PM
meck1's Avatar
meck1
Okay, with the weather's cooperation I was able to get a little work done. I pulled the computer codes and got one only, a #32, an EGR fault code. The EGR seems to be moving fine, and the EVP checks out. I'm not sure where to go on this or how it can be causing the weird idling miss that I'm getting.
I also heated up the TPS with a hair dryer as you suggested. It made no difference in the problem.
Does anyone have anymore hints or suggestions as to what I can check?
Thanks
Old Nov 24, 2003 | 10:13 AM
sicbpguy's Avatar
sicbpguy
I'm sure how the EGR would cause a miss. It can cause a rough idle, but that does not sound like your problem. Make sure you check the EGR vacuum regulator on the side of the valve cover ( trace the vacuum lines back) and check the vacuum lines to make sure the vaccum is getting to the EGR to make it work.
Old Apr 7, 2006 | 11:11 AM
meck1's Avatar
meck1
Mysterious miss solved
After more than two years of messing with this truck ('87 F250) trying to find a miss, changing one thing and another, testing every source of vacuum leak, ignition misfire, sensor malfunction, etc. the mystery is over. A well worn cam and lifters were causing the problem. It's running like a charm again, and I picked up 2.3 mpg additional. Thanks for all the advice everyone on the list gave during the couple of years.
VR666
13
Jun 16, 2015 11:14 AM
drjoe171
Jan 15, 2011 05:11 AM
twinzilla
Feb 7, 2010 09:40 PM
meck1
26
Oct 12, 2004 03:33 PM
meck1
Apr 21, 2004 07:59 PM
