is thermostat essential?
Old May 23, 2004 | 01:17 PM
c_rossman's Avatar
c_rossman
You need the restriction to increase PSI inside the block to prevent cavitation. The increased psi in the block brings up the boiling point of the coolant thus preventing hot spots.
Old May 24, 2004 | 04:48 PM
EPNCSU2006's Avatar
EPNCSU2006
^ not to mention heat transfer principles. The water absorbes and dissipates more heat the longer it stays in the engine and in the radiator. If no thermostat is present, the water moves too fast to transfer the proper amount of heat, and is inefficient.
a711112a
Mar 1, 2011 08:19 AM
elwood
Jun 10, 2003 05:32 PM
blownbronco
1978 - 1996 Big Bronco
23
Dec 12, 2002 01:24 PM
