plug order
Old May 20, 2004 | 05:28 PM
ajd77900's Avatar
ajd77900
Exclamation plug order
92 f150 302 what are the cylinder numbers one the block starting at the front of the engine going towards the firewall on the drivers side and then the numbers for the passenger side thanks
Oh where is the ACT sensor located on my engine
Thanks
Old May 20, 2004 | 05:47 PM
fai4g63's Avatar
fai4g63
pass. side timing cover to trans 1234 drivers side timing cover to trans 5678
Old May 24, 2004 | 04:54 PM
EPNCSU2006's Avatar
EPNCSU2006
The ACT is either in the airfilter housing or in the intake manifold between the injectors for cylinders 5 and 6.
