Ford's Powercode Remote Start
Old Apr 19, 2004 | 07:40 PM
NY-Ford-Lifer's Avatar
NY-Ford-Lifer
Anyone have any experience installing a Ford Powercode remote start system? It seems like it's a direct plug module under the dash but the local parts department guy says it's pretty involved and should only be dealer installed.
Old Apr 19, 2004 | 08:01 PM
1956MarkII's Avatar
1956MarkII
I hope you haven't bought it yet- they're junk. Very expensive, and we've had nothing but trouble with the ones we've installed. We've gone to having a local accessories shop install an after-market unit for less than half the price, and no problems.
Old Apr 20, 2004 | 07:20 AM
firenlaw's Avatar
firenlaw
I had one installed about 3 months ago and haven't any problems. It has a long range and its nice having everything on one remote.
Old Apr 20, 2004 | 08:57 AM
JRROTH1's Avatar
JRROTH1
I have a Viper 790XV alarm system on my Screw which has remote start and is a 2-way system so you get feedback/status from the system. It's supposed to have the best range in the industry but I haven't tested that yet. It also lets you know when you (keyfob) are out of range - I can say that that hasn't happened to me yet - even in the mall . . . I had it installed for a total cost of $440. You can see details here:
http://www.drdetailshop.com/V790XV.htm
Also you no longer need the stock Ford keyfob since the alarm keyfob locks and unlocks your doors also. It just takes a little getting used to the larger keyfob (LCD display)
The Ford systems seemed overpriced for what they offered! I would definitely check aftermarket before you decide on the Ford. . .
Old Mar 6, 2006 | 04:51 PM
MERENE3's Avatar
MERENE3
anyone have problem with remote starter not starting after sitting overnight and only way to get it to start is unlock truck insert key start truck then turn it off and use the remote then it works?? have a 2006 (gold) powercode installed on a 06 F-150 supercrew 4x4 5.4 and trys to start lights come on and fuel pump kicks but no starter...? help its a dealer again twice in 1 week .. only has 200 miles on it ..
Old Mar 6, 2006 | 06:02 PM
TWellmann's Avatar
TWellmann
Similar to JRRoth1, I have the 2-way Viper system on my 04 SCrew. I have had the version without the alarm for two years now and it has worked flawlessly for me.
Old Mar 17, 2006 | 02:04 PM
MERENE3's Avatar
MERENE3
Dealer Said Was Loose Pin Connector After 3 Days .. Ya Right.. Now Door Locks Not Working Right,,, Dealer Installed Auto-starter Piece Of Junk.. I,m Soooo Madd Only Have 500 Miles On Truck Now .. Going Back To Dealer On Sat. In Am We Will See.. 06 Supercrew 4x4..xlt.
Old Mar 17, 2006 | 04:23 PM
SteveVFX4's Avatar
SteveVFX4
Merene3, sounds like they did a bad install. As far as working after you put the key in, and then hit the remote and it works, it seems like a problem with the PATS bypass antenna. The antenna ring might not be properly attached to the ignition column, or wasn't properly programmed with the 2 master keys.
This website will help you guys, it has the install manuals for all Ford vehicles:
www.gemsen.com/ford
Old Mar 17, 2006 | 04:59 PM
tomdoggie's Avatar
tomdoggie
Had mine installed by the company that installs for my dealer. Works great,
my truck sits out, so its really great on cold mornings.
Old Mar 17, 2006 | 07:25 PM
MERENE3's Avatar
MERENE3
thanks steve just what i needed.. will take with me to dealer..
Old Mar 31, 2006 | 10:34 AM
MERENE3's Avatar
MERENE3
Steve Thanks For The Help... Took That Info To Dealer And Talked To Mechanic That Was Working On Truck And Last Guy Programed Wrong When I Had A Problem With Brake Light Short And That Dealer Did Not Install The Optional Relays For The Door.. But They Installed It On That Saturday And Reprogramed It And Works Ok Now.. (note He Found That The Dimmer On Headlight Switch Was Bad Most Likley From Short) And That Is Why Would Not Program Right And Work Correct.. But Ok Now.. Thanks Again Steve....
Old Mar 31, 2006 | 03:52 PM
SteveVFX4's Avatar
SteveVFX4
Glad it worked out for you. I had installed the Ford kit myself in the past on my old 2002 Sport Trac, and a friends 02 F-150. It is so time consuming. I decided to pay someone do install this time on my 04 truck. They did an ok job but they didn't hook up the dome light wire. Without that wire hooked up, I couldn't get into the programming options. Luckily I found that website. So I was able to hookup the dome light properly, and while I was at it, I hooked up my side mirror defrosters to the AUX1 output on the system. So I press and hold the button to start my truck, and then after it starts, I press the button one more time and it turns on my mirror defrosters.
Steve
2jhanna
2009 - 2014 F150
Dec 17, 2016 07:21 PM
Buck 1
2004 - 2008 F150
Jan 21, 2014 07:19 PM
Ranger1F150
Escape & Escape Hybrid
Dec 21, 2009 05:52 AM
V8EXPLR
2004 - 2008 F150
Jul 14, 2009 01:54 PM
FadeToBlack
2004 - 2008 F150
22
Apr 27, 2004 08:00 AM
