speedometer and odometer quit
Old Oct 10, 2002 | 08:36 AM
eric3t's Avatar
eric3t
anyone know what would cause this to happen? fuse? this happened suddenly...was working fine before
Thanks
Old Oct 10, 2002 | 03:38 PM
alanscott's Avatar
alanscott
>Thanks
A little info about your vehicle would help.
Old Oct 10, 2002 | 05:13 PM
eric3t's Avatar
eric3t
sorry...1999 PSD auto 3.73LS 143,000 miles all stock
Thanks
Old Oct 10, 2002 | 07:26 PM
Monsta's Avatar
Monsta
Sit. Stay.
Ddi you try replacing the speed sensor located on top of the rear diff? It is only around 12-15 buckaroos. It gices the computer the actually road speed of the truck. Don't know if it will fix it but it's a rather cheap place to start...
<on edit>
Are you experiencing any drivability concerns?
If not, then I probably wouldn't suspect the sensor, since the computer also obtains "tuning" parameter input from it.
Old Oct 11, 2002 | 01:04 AM
alanscott's Avatar
alanscott
I can't remember where, but I've also read where a guy had problems with the ground strap to his dash. You might check that also.
Old Oct 11, 2002 | 06:23 AM
gseeders's Avatar
gseeders
>Thanks
first thing, check all fuses. inspect all light and repair if needed.
I had a 94 f150 that this happen to and the problem was the third brake light/cargo light just above the rear glass. when the factory installed the light a wire was pinched between the light housing and the metal body and grounded out. If the speed sensor was out I think that your service light should be on. Check your owners manual to see what other devices that maybe involved with the speedo circuit.
good luck
over and out
gseeders
Old Oct 11, 2002 | 08:42 AM
Monsta's Avatar
Monsta
Sit. Stay.
Most of the time the light does not illuminate for the speed sensor.
Checking all the electrical connections is a great idea!
Old Oct 11, 2002 | 09:50 AM
eric3t's Avatar
eric3t
Thanks for all the ideas...I didn't think they were all interconnected but this all began after the batteries were drained...after charging the batteries, the service engine light,abs came on and the overdrive light began flashing... after driving the truck awhile, I then noticed the speedo and odo were not working...I was trying to tackle on problem at a time...I should have given all this info before
Thanks
Old Oct 11, 2002 | 02:05 PM
alanscott's Avatar
alanscott
How did you charge the batteries? I hope you didn't somehow get a voltage spike and zap the ECU. You might try disconnecting the batteries for a few hours to reset the ECU and go from there.
Old Oct 18, 2002 | 02:37 AM
eric3t's Avatar
eric3t
Where is the ECU? Can you describe what it looks like? How much to replace? Is it easy to swap?
Thanks
Old Oct 18, 2002 | 07:54 AM
JoeBoost's Avatar
JoeBoost
Old Dec 6, 2004 | 09:26 PM
frybronco's Avatar
frybronco
my dads 1999 did that when it was fairly new it was probably in 2000 but would have had about 50000 mi and i cant remember what it was but i think thaqt it was a common problem. they told him it would probably be recalled but i dont know if it ever was
Old Dec 6, 2004 | 09:46 PM
clux's Avatar
clux
Thanks
I vote for the speed sensor.
Old Dec 7, 2004 | 01:11 AM
psdpower's Avatar
psdpower
Abs light, overdrive light flashing, no speedo, all common syptoms of a bad speed sensor. As stated before less then $20 from Ford and about a five minute job to remove and replace. I would start there before chasing electrical gremlins.
SpringerPop
General Diesel Discussion
34
Mar 6, 2008 04:20 PM
Talyn
13
Oct 23, 2007 10:49 AM
JReinert
Feb 26, 2006 05:54 PM
GMFDBob
May 8, 2002 12:25 AM
Water Dog
Arizona Chapter
Apr 7, 2002 10:34 AM
