Temp. Gauge ?
Old Apr 16, 2004 | 03:01 PM
79blueoval's Avatar
79blueoval
Temp. Gauge ?
The temp. gauge on my 79 F-350 w/400 is reading to the high end of the normal scale when fully warmed. I checked the coolant temp at 165 degrees,changed sending unit twice(once it was broken, second because of gauge reading) and I even changed the instrument cluster and still get same reading. Any ideas?
Thanks.
Mike.
Old Apr 16, 2004 | 03:51 PM
Phinxter's Avatar
Phinxter
Sounds like you got the wrong temp sender. I just got my gauge working and it used a GP Sorenson TSU103. The parts guy said about all used this one.
Old Apr 16, 2004 | 10:01 PM
Mil1ion's Avatar
Mil1ion
There are 2 different S/U's
One for the Idiot light & another one for the gauge.
The temp seems low.
I wouldn't go any cooler than a 180* T-stat.
The engine should run around 210-215 with the proper mix of water/coolant.
Old Apr 17, 2004 | 01:20 AM
Torque1st's Avatar
Torque1st
Posting Legend
Dennis is correct use the recommended 195 stat or 180 minimum. Do any of your other gages read high? If they do you may have a bad instrument panel volatage regulator.
Old Apr 17, 2004 | 01:50 AM
TNTsF-250's Avatar
TNTsF-250
Is your temp. gauge reading between { NORMAL } pick a letter, or higher ? how hot is it out side , Is it reading high on the freeway ? or stop and go ( city) TNTsF-250 good luck.
Old Apr 21, 2004 | 04:30 PM
79blueoval's Avatar
79blueoval
Thanks for the replys!
I need to put a different gauge on it and see where the problem is and go from there.
Old Apr 21, 2004 | 11:39 PM
ivanribic's Avatar
ivanribic
I'm sitting at 190-200* now. Is that too cool? I was getting 215-220* but was worried that it was a little high. Think my T-stat is 190* but I added a second fan to keep the temp down. Of course it's been too cold to predict what will happen in summer temps.
kawa
29
Feb 14, 2008 07:17 PM
vortec
Nov 1, 2007 10:47 AM
missouguy
Jan 27, 2005 01:07 AM
trvarnado
Electrical Systems/Wiring
Sep 13, 2003 10:50 PM
jeffreysw
Aug 11, 2002 04:05 PM
