1995 5.0 EFI problems
Old Apr 15, 2004 | 09:13 PM
95 F150's Avatar
95 F150
Hello everyone my 95 F150 has developed a strange problem that I cant figure out. My engine is a 5.0 EFI with mass air and an auto trans, mileage is about 107K. Okay now for the problem, when I'm acelerating with light to medium throttle my truck is bogging real bad in the low rpm range 1200 to 2300 rpm range, it feels like the timing is being retarded then when you get to the 2300 rpm+ range it feels like the timing advance kicks in and it suddenly wakes up.
I have checked my base timing and it is set fine, the cap, plugs, rotor are all fairly new and were put on after this problem started. Any ideas would really be apreciated.
Old Apr 15, 2004 | 09:16 PM
95soontobelifted's Avatar
95soontobelifted
maybe some injection cleaner?
Old Apr 15, 2004 | 09:19 PM
95 F150's Avatar
95 F150
Oh yeah , I ran Techron fuel injecter cleaner through the last two tanks also.
It feels like the computer is pulling timing in the low rpms.
Old Apr 15, 2004 | 11:48 PM
EPNCSU2006's Avatar
EPNCSU2006
I'm not too familiar with that year truck, but did the 5.0's still have a knock sensor? You might also want to try cleaning the heated wires in the MAF sensor. I don't know if that would cause it to bog like you say, but it can't hurt anything. Might also want to check your TPS voltages.
Old Apr 16, 2004 | 12:08 AM
Leo_T's Avatar
Leo_T
CEL coming on? I assume not, or you would have mentioned it.
Old Apr 16, 2004 | 12:20 AM
Fordtech1's Avatar
Fordtech1
MAF? TPS? Try unplugging MAF and accelerate, if it is better, clean or replace. Unplugging the spout connector will keep timing from being computer advanced.
Old Apr 16, 2004 | 05:53 AM
95 F150's Avatar
95 F150
Thanks for the input guys, I scanned for codes and none were stored in the computer, I've checked and cleaned the mass air sensor and it looked okay. The knock sensor sounds like something I should check out. Does anyone know where it's located?
Old Apr 16, 2004 | 06:38 AM
EPNCSU2006's Avatar
EPNCSU2006
If Ford used one that year, it would be all the way in the back, threaded into the block just behind the intake manifold.
duckwing
Sep 22, 2014 06:03 PM
1994F2507.3L
Jan 8, 2014 05:34 AM
kemerick
1983 - 2012 Ranger & B-Series
Jul 14, 2009 03:17 PM
whygoslo
Mar 25, 2003 01:47 PM
fordkid
Jan 2, 2002 07:25 PM
