fixed one problem and uncovered another
Old Jan 6, 2014 | 07:30 PM
1994F2507.3L's Avatar
1994F2507.3L
So I changed torque converter and now I've got another problem. When I changed converters it dropper my 60 mph rpm to 1900-2000 from 2200-2300 so now I have a noticeable miss in that rpm range that I can't figure out. Has anyone else had that problem? It was there before but not as noticeable I guess because I wasn't in t that rpm range much. Also I did the oil cap blow by test and the cap doesn't move so no blow by. Also I have no check engine light and hpop was replaced by one of the po it says bosch on it
Old Jan 6, 2014 | 09:52 PM
idt-572's Avatar
idt-572
Could it be your converter trying to lock and shuddering like an engine miss?
Old Jan 6, 2014 | 10:22 PM
1994F2507.3L
it will do it in park no load if I hold the accelerator to 2000 rpm
Old Jan 6, 2014 | 10:31 PM
oldbird1965's Avatar
oldbird1965
Seems to me that the rpm drop is because the new TC was locking when the old one wasn't. Was the trans running hot before the switch?
Old Jan 7, 2014 | 09:04 AM
1994F2507.3L
It wasn't running got because were in negative temps here and I have a external cooler on it but it was running at 120 where now it's at 100. I'm wondering if the miss could be related to the injector orings or cps
Old Jan 7, 2014 | 09:19 AM
oldbird1965
cps is always a cheap one to try, get it from Ford. The parts store ones are junk, you should carry a spare anyway.
Old Jan 7, 2014 | 09:42 AM
1994F2507.3L
I have one from Ford in the glove box I just was hoping that someone had also experienced this and had a for sure fix, it seems off that it happens only at that rpm and isn't logging codes for a cps if that were it. I have access to a modis computer next week and was going to see what fuel system test I can run with it to try and isolate the problem but I won't have it until next week at the earliest I've spent quite a bit on the truck this past month and I'm just hoping it's not an injector going
Old Jan 8, 2014 | 05:34 AM
1994F2507.3L
I think I'm going to try the cps today I'm hoping that's it otherwise I wasted that part and still have to spend more on there stuff lol
dmueller71
Nov 22, 2024 09:21 PM
Gerby Dutchy
2009 - 2014 F150
Oct 29, 2013 01:44 PM
sand1
Nov 5, 2012 03:20 PM
CNC
Feb 8, 2010 05:16 PM
BURNSTOUGHFORD
1997 - 2003 F150
Feb 17, 2009 01:58 PM
