Ford E7TE Heads, Please Help!!!
Old Apr 15, 2004 | 01:10 PM
Jolbca1962's Avatar
Jolbca1962
Lightbulb Ford E7TE Heads, Please Help!!!
I am trying to find the cumbusion chamber volume for Ford E7TE heads. Some sites say 60cc to 63cc. Please give me your input
Old Apr 15, 2004 | 02:01 PM
Ford427Strokr's Avatar
Ford427Strokr
The E7 castings range from 60.3 to 63.6. Some say 64 and I have heard 69? But should be around 9.5 to 1 compression with stock pistons. I have a set of GT-40 P heads and they are 59cc chambers.
Old Apr 28, 2004 | 09:30 PM
superhooperduty's Avatar
superhooperduty
gt40p heads
the gt40p's i'm looking at say 60cc, what are these on, how may springs on the valves?
Old May 3, 2004 | 05:29 AM
Ford427Strokr
The heads i have are still in the box. You can find them on 97 or 98 up 5.0 explorer/mountaineers.
Old May 3, 2004 | 02:54 PM
superhooperduty
screwed
got the gt40p heads installed, sounded like the tappets rattling, found the holes for the push rods are too small, rods touch against the side of the holes, drilled 2/3 the way afrom bottom 1/2" in dia but the top 1/3 is between 3/8" and 7/16". anybody else have this problem, took off heads to confirm this and noticed #4 cylinder gouged, wrist pin let loose, having it resleeved and bored out to fit piston, hope machine shop will cover part of this, but they say not our fault, considering they pressed the pins in, i think they should pony up some for this, don't you?
Old May 4, 2004 | 03:59 PM
94F150-408's Avatar
94F150-408
Jolbca do you already have a set of these heads or access to them so you can check them yourself to find out the cc?
Old May 4, 2004 | 04:26 PM
Jolbca1962's Avatar
Jolbca1962
Talking
Yes I do and I will check the volume Thanks
CoyoteBevel
Arizona Chapter
Dec 1, 2017 09:26 PM
cortina219
Aug 21, 2013 08:17 PM
cujo8
May 19, 2006 05:12 PM
bivens1172
Mar 29, 2006 09:39 AM
lisagoud
Oct 15, 2004 04:24 PM
