Sponsored by: Real Truck
Rotors
Old May 6, 2004 | 07:25 PM
  #31
daimon1054's Avatar
daimon1054
My tire do that, rotating them helps but the real problem is the twin I beam, the weight causes the tire to bounce. As the shocks get worse so does the wear changing to a good set of shocks help.
Old May 8, 2004 | 05:51 AM
  #32
Gwilkrrs's Avatar
Gwilkrrs
im thinking of rotating the tirs and putting new shocks on but i still have a rotor issue. mine is a 1 ton so no I beams here.
Old May 9, 2004 | 11:26 AM
  #33
03f350crew's Avatar
03f350crew
Originally Posted by Gwilkrrs
my tires are wearing funny in the front but down the road no vibration under brakes wow a whole nother stort the wheel actually vibrates and shakes and makes passengers uneasy......
Maybe a bent rim. All three of our work truck had this problem. They were all 2wd 1tons and the front rims had bent or warped. The tire shop we used said that they had seen this on several fords and they summed it up to a bad batch of wheels from the factory. Sure enough as soon as some new rims were installed the vibration in the front end went away. This vibration wasn't just a minor thing either, the stearing wheel would violently shake back and forth.
Old May 9, 2004 | 07:16 PM
  #34
Gwilkrrs's Avatar
Gwilkrrs
i guess ill stop buy the tire shop ti have the wheels checked. thanks for the in put..
Crewcab Turbo
39
Apr 20, 2012 11:35 AM
nebechanezer
Feb 28, 2011 11:05 AM
CarCrazy1001
Aerostar
Jun 19, 2010 09:30 PM
stone75
1997 - 2003 F150
Apr 22, 2007 08:43 PM
ckrichard
Dec 12, 2003 08:47 PM
