Sponsored by: Real Truck
Rotors
Old Apr 14, 2004 | 08:05 PM
Gwilkrrs's Avatar
Gwilkrrs
Rotors
what type of replacement rotors are you using to eliminate the warping issues? what is there price? how do you like them?
Old Apr 15, 2004 | 09:27 AM
Foneguy's Avatar
Foneguy
ART.. Do a search on them.. I have them on My SD.. and no complaints.. there are lots out there... do some research and see what works best for you. I paid about 650 for mine which included shipping and a set of full replacement pads all the way around.
YMMV
Your Resident Foneguy
Old Apr 15, 2004 | 09:48 AM
jim henderson's Avatar
jim henderson
I bought Raybest Rotor for my 250. It was a beautiful piece of work and so far has done splendid duty on my truck which is used to tow an 8,000# trailer.
I think I paid something like $70 for it. The dealer sells only complete hub assemblies for $250, junkyards wanted $150 and the Chinese POS were something like $50 and the lifetime NAPAs were something like $90.
Good Luck,
Jim Henderson
Old Apr 15, 2004 | 10:03 AM
mattsf250's Avatar
mattsf250
650, FOR ROTORS!!!
ohh man..... looks like ill be goin to pep boys for some reybestos every 6 months.... my front rotors are shot, with only 21k on the clock.
Old Apr 15, 2004 | 10:09 AM
Foneguy's Avatar
Foneguy
I know that seems like an awful lot.. but with all the research i have don'e on the different makes and with all the feedback I recieved. ART. was the way to go fro me. I've seen proof that these rotors have gone more than 100k.. and still haven't needed to be turned. when a company doesn't mass produce items and only makes to order.. I was pleased to hear that each part gets individual attention to detail..
as always
YMMV
Old Apr 15, 2004 | 02:50 PM
03f350crew's Avatar
03f350crew
Question Rotor concerns
I have a vibration that just started in the front end that I only feel above 70mph. I had hoped that it was the tires needing balanced but after reading this thread I am thinking maybe the rotors are warped. The only problem is that I don't feel any vibration when applying the brakes which usually is the sign of warped rotors.
Old Apr 15, 2004 | 02:57 PM
Foneguy's Avatar
Foneguy
The is sounds as if your tires may need to be ballanced or are out of round... you may also want to have your barrings looked at.. if you feel the vibration in the steering wheel or the pedals it's most likely in the front. If you feel the vibration theyour seat or on the floor then it's most likely the rear.
YMMV
Old Apr 15, 2004 | 03:21 PM
03f350crew's Avatar
03f350crew
Vibration is in the stearing wheel and the wheels were just balanced and rotated but I need to check them again at 70 mph to make sure it has gone away. Wheel bearing should be ok the truck only has 15,000 miles on it. Thanks.
Old Apr 15, 2004 | 03:37 PM
Foneguy's Avatar
Foneguy
if you could give me some more info on your rig it would be helpful... Auto/Manual, tiresize lift, Etc.
thanks
Old Apr 15, 2004 | 04:50 PM
Gwilkrrs's Avatar
Gwilkrrs
thanks fellas. ill research them in my spare time. 650 is a lot for me right now, but i need rotors. my fromt tires are showing odd ware too but i was told might be wheel bearings too. truck has 39k.
Old Apr 15, 2004 | 06:40 PM
03f350crew's Avatar
03f350crew
03F350 4x4 Diesel 6.0 stock.
Old Apr 27, 2004 | 05:04 PM
03f350crew's Avatar
03f350crew
Turned out that left front tire was off by 5 oz. Runs smooth now!
Old Apr 27, 2004 | 06:52 PM
unit5alive's Avatar
unit5alive
I got the 13" rotors on my 350z drilled and slotted by the brake warehouse in the carolinas,they have to be done when new before you drive the vehicle ,so they do not get tempered,they also heat treat/nickel plated balance them ,about $450 with shipping($85) for all four,contact randy. ps. they do a lot of work for nascar,excellent work!
Old Apr 27, 2004 | 10:32 PM
02superstroker's Avatar
02superstroker
What do yall think of these guys... They are about mid page, called "severe duty rotors" They are slotted and drilled. I wonder what the price might be? I just cant see myself spending upwords of 400 dollars for rotors.
Rotors
Old Apr 28, 2004 | 08:56 AM
Jerrod's Avatar
Jerrod
How about the performance friction rotors? I notice the ART rotors come with perfomance friction z rated pads. So their product must be good if ART is using the pads. How about their rotors?
