VIN decoder?
Old Apr 13, 2004 | 11:29 PM
aztsm's Avatar
aztsm
VIN decoder?
Can you guys point me to a VIN decoder for a 1970 F250?
Regards
Old Apr 14, 2004 | 12:00 AM
390fe's Avatar
390fe
Try here:
http://www.medicine.wisc.edu/~mrm/bronco/ftvin.cgi
Old Apr 14, 2004 | 06:40 PM
mk's Avatar
mk
Post your numbers here- give us something to do
mike
Old Apr 15, 2004 | 03:06 PM
seabee04's Avatar
seabee04
I am having trouble with the same (VIN)
My vin is 1GKDM19W5XB505862. I just bought this truck a 2 months ago. thanks for all the help.,Dave
Old Apr 15, 2004 | 04:32 PM
Mil1ion's Avatar
Mil1ion
Seebee, You need to post yours in the applicable forum.
That being the year of your truck going to its own tech forum.
This forum is for 67-72 trucks
Old Apr 16, 2004 | 12:43 AM
seabee04's Avatar
seabee04
I thought I did. This is a 72 Ford F250 Pick-up. This forum is for my truck, i thought. Mil1ion, i hope that this is correct. Please reply. Does the vin # show this not being a 72? thanks so much.
(confused) David
Old Apr 16, 2004 | 10:20 AM
Mil1ion's Avatar
Mil1ion
That VIN# is not from a 72.
Up until 1980 the vin has 11 digits.
Old Apr 16, 2004 | 06:28 PM
mk's Avatar
mk
David, at first you said 70, now it's a 72? No matter. The format of the serial numbers for these trucks would be something like this example:
-F25YCN18000-
The number you gave us is from something far newer and maybe even GM to boot. ( going by the first two digits-1= US built G= company: General
Motors. The eight digit is the year code letter and I think W is for 99)
mike
Old Apr 16, 2004 | 08:20 PM
seabee04's Avatar
seabee04
Thanks Mike, I will double check the Vin #. So sorry for any trouble I have caused. Really like to read all of these threads. You have helped me out so much in getting this truck running. May I double check the Vin and re-post #? Again thanks for everything,
David
Old Apr 16, 2004 | 11:33 PM
seabee04's Avatar
seabee04
Mike,
Even us old Navy retired guys can finally get it right (lol). The right number is F25YRM82658. I had to count this twice to make sure it add's up to 11. Thanks so much for patience.
EDIT:
i went to the above web site and it was nteresting but it did tell me trans type or rear axle type. Here is the info on the door plate. can anyone make heads or tails out of it.
131 M2 F253 E 4 6 38
08100 151 4000 71
Thanks, dave
David
Old Apr 17, 2004 | 12:40 AM
Mil1ion's Avatar
Mil1ion
F25 = F250
Y =Engine =360
R = Plant built at = San Jose
M82658 = Consecutive buiild # 1972 ?
131 = Wheelbase 131"
M2 Paint code = Two Tone--
M = Wimbledon White
2 = Royal Maroon
F253 - Body suspension code =8100 Lbs
Body codes
E = Vinyl Bench seat
4 = Styleside
6 = Transmission should be a G ( not a 6) = Automatic = C6 ,C4 ?
38 = rear axle code = 3.73:1
08100 = GVRW = 8100 lbs
151 hp @ 4000rpm's
71 = DSO code = truck sent to Los Angeles
Old Apr 17, 2004 | 04:55 AM
ACESN8S's Avatar
ACESN8S
Originally Posted by Mil1ion
Y =Engine =360
6 = Transmission should be a G ( not a 6) = Automatic = C4
Uhmmm, yeah. I'm pretty sure that someone at the plant was smokin' something when they did some of the VIN's.
seabee, if you have an A/T in your truck, it'll be a C6. Although the code says that it's a C4.
I've found that decifering codes on some of these trucks will help you go bald, from pulling your hair out
Old Apr 17, 2004 | 11:05 AM
dorslv's Avatar
dorslv
my vin #
hi, can you guys decode my VIN# it's F25YKP02490 it's a 1972 F250 Custom with a bad motor, manual transmission. thx
Old Apr 17, 2004 | 12:19 PM
Mil1ion's Avatar
Mil1ion
F25YKP02490
F25 = F250
Y = 360
K = Kansas City
P02490 = Consecutive build number.
Old Apr 17, 2004 | 02:09 PM
dorslv's Avatar
dorslv
vin
thanks for the reply, I am thinking of rebuilding the motor and T-18 tranny do you know any good places to start? shops etc...
