VIN decoder?
Old Apr 27, 2004 | 01:10 PM
  #31
SFC DAVIS's Avatar
SFC DAVIS
MrCrewCabFordGuy- my bad... F250 2WD. Was reading the decoder to fast.
Old Apr 27, 2004 | 11:15 PM
  #32
MrCrewCabFordGuy's Avatar
MrCrewCabFordGuy
SFC DAVIS, np on the decoder, I appreciate the information.
Old Apr 30, 2004 | 08:09 PM
  #33
1950t's Avatar
1950t
4 door?
the truck is a 4 door could that be what it is? thanks
Old May 2, 2004 | 04:21 AM
  #34
MrCrewCabFordGuy
This truck is a four door crew cab, two wheel drive, had a V8 engine with a manual transmission, it now has the C6 transmission and 429 c.i. I was wondering about the F250 and the long bed also, wanted to know what, when and where this truck came from, color, engine, tranny and such.
Old May 2, 2004 | 10:02 AM
  #35
sub360's Avatar
sub360
Thumbs up
Hey Steve, Got my problem squared away. Instead of addressing customersaskford.com, I clicked on the live link you posted here on 22 April. What a difference that made. I put my VIN info in that new screen and it would appear I will be getting my data sheet in a few weeks. I'm not only learning about old Ford trucks but a little about computers as well. Will it ever stop? No!
Old May 11, 2004 | 02:09 AM
  #36
majaflo's Avatar
majaflo
Can you try this one please?
F25YLC99559 M 56
F253-81-38-G 56492
04-01-68 FLT 04-01-70
I sure hope this does not mean it was manufactured on April Fools Day!!!
Thanks!
Old May 17, 2004 | 07:24 PM
  #37
mk's Avatar
mk
Where did you get that last line?
mike
Old May 17, 2004 | 07:29 PM
  #38
majaflo's Avatar
majaflo
It was on the original dealer tag that was given to the new owner in 1968. It's a plastic card with all the numbers on it from the factory.
Thanks!
mike
Old May 18, 2004 | 07:53 PM
  #39
mk's Avatar
mk
Here's what I found out...
F25- F250 2WD
Y- 360 V8
L- Michigan assembly
C99559- scheduled production date Mar 68. You can pin the build date
down a little closer by check-
ing date codes on the upper
seat back tag and date codes
cast and stamped into var-
ious engine ( cyl block has
date cast above starter)
and sheet metal parts.
M- Color-Wimbledon White
F253- 6100 GVW
81- Conventional cab
38- Axle-3.73 Dana 60
G- Auto trans C6
56492- Looks like it should be the DSO code but I couldn't find a
sales district numbered 56. Check your door tag to see
if these numbers match.
The 04-01-68 may have been the purchase date and the 04-01-70
was probably the date the warranty ran out.
Hope this helps.
mike
Old May 18, 2004 | 08:08 PM
  #40
majaflo's Avatar
majaflo
Thank YOU!!
This was a HUGE help. I've tried every source known to man to try to figure the vin on this thing. Now..............all I need is an original radio for this truck and this year and it will 100% complete. Any suggestions??
Super Job!!
Rachel
Old May 20, 2004 | 08:38 AM
  #41
scottinmt's Avatar
scottinmt
I would appreciate any information you can give me on my 1970 F250
F25HRJ16270
Thanks!
Old May 20, 2004 | 07:28 PM
  #42
mk's Avatar
mk
Scott, yours translates to an F250, 390 V8 built in San Jose sometime in May 1970. There's other codes on the door tag for trans, axle, color, sales district, etc.
mike
Old May 20, 2004 | 10:08 PM
  #43
scottinmt's Avatar
scottinmt
the door tag reads as follows
F25HRJ16270
WB 131
Color 2P
Model F254
Body F
Trans 4 G
Axel C7
max GVW 6900
cert net hp 180 (is that all!?)
RPM 4000
DSO 74
Thanks, appreciate your help!!!
Old May 20, 2004 | 11:20 PM
  #44
denisontexas's Avatar
denisontexas
Please assist with VIN decode for 67 F100 -
Can anyone direct me to VIN decoder for a 67 F100 ?
F10YRB28605
F10=F100
Y=352 series
R=California
B
605=?
Thanks
Old May 21, 2004 | 12:27 AM
  #45
Mil1ion's Avatar
Mil1ion
DSO 56 is for Davenport.
56492
The 3 numbers after it means it was the 492 ordered truck for that zone.
