vacuum leaks
Old Apr 13, 2004 | 03:32 PM
aj10's Avatar
aj10
vacuum leaks
can anyone out there tell me the best way to hunt down a vacuum leak? i have been told i have a leak on my 85 f-250 4x4 with a 351w. i recently put on a new holley truck avenger carb. i have heard of using a bottle of water with some soap in it, but that didn't do a thing, and i found no changes in how the engine ran. the truck runs, but not well. it takes a while to get the truck idling, without me having to rev the engine. thanks for any imput
Old Apr 13, 2004 | 05:08 PM
Big Orn's Avatar
Big Orn
I always use WD40. It makes the engine rev a little higher when the vac sux on it.
I've never heard of the water/soap thing? It would work on pressure, bubbling and all, but how in the world could you detect a vac leak with it?
Old Apr 13, 2004 | 10:23 PM
mustange70's Avatar
mustange70
the soap thing works if the air is blowing and not sucking (it makes bubbles) there a tool you can get that uses smoke to find leaks or even a mechanics stethiscope thingy will work to.
Old Apr 14, 2004 | 09:14 AM
mchild's Avatar
mchild
aj10,
I would be glad to give you a detailed guide to search for leaks, but since I'm just getting back from a week off it has left me with too much to do. I have given this same advice to others in the recent past so you should be able to find my postings if you do a search on vacuum leaks in this forum, the carb forum, and the 460 engine forum.
Good luck,
Mark
Old Apr 14, 2004 | 06:55 PM
madman672's Avatar
madman672
Use A Propane Torch
Do Not Ignite It Just Turn On The Gas And Point It Where You Suspect Leaks If The Engine Revs Up Youv'e Found It
sgtnike
2004 - 2008 F150
Mar 21, 2013 11:50 AM
Kyo
Feb 7, 2013 06:29 PM
George Frasier
Jul 18, 2011 06:50 AM
xc4jokestomper
Oct 30, 2010 07:00 AM
Redcat Diesel
Jan 25, 2009 01:31 PM
