Running Rough, Vacuum leak?
Old Mar 21, 2013 | 09:44 AM
sgtnike's Avatar
sgtnike
Hey Guys, I have a 2005 F150 4X4 Triton 5.4. She is running rough and my A/C and Heat will ONLY blow out of the floor vents. Seems like a vacuum leak to me. But I can't find any vacuum lines that are obviously broken or leaking. ANY HELP? Thanks,
Sgt Nike
Old Mar 21, 2013 | 11:50 AM
sgtnike's Avatar
sgtnike
It turns out that this is 2 separate issues.
1. When the previous owner replaced the spark plugs, he put the #4 ignition coil on top of the fuel injector wire and not to mention that some water accumulated in the spark plug housing making the truck run rough. RESOLVED
2. I'm still working on the A/C issue. I have vacuum in the line against the P/S firewall in the engine compartment. I'm going to check the switch behind the center console, as soon as I figure out how to remove the front panel.
sgip2000
Mar 19, 2015 11:24 PM
dharte
Nov 1, 2014 06:28 PM
LV Dan
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 8, 2004 07:38 PM
LV Dan
Sep 7, 2004 03:17 PM
