Engine light / vacuum leak
Old Jul 17, 2011 | 10:42 PM
George Frasier's Avatar
George Frasier
Unhappy Engine light / vacuum leak
Had a 'puter diagnostic' that said I have a vacuum leak.... I have propane cylinders to check out a leaky line but don't know where the vacuum lines and just how many there are. - 2000 Explorer - 3.8L - AT - 4x4 Could somebody post a diagram or ?? to let me know just where to look. I'd rather 'do' an old Ford, MUCH simpler. Thanx ahead.
Old Jul 17, 2011 | 10:55 PM
steve(ill)'s Avatar
steve(ill)
it helps if you post the code, and not the mechanics interpretation of what the code means... you could have an intake manifold gasket leak ? vacuum hose heat cracked ? or other. Dont use propane, just look for burn or brittle hoses... and post code.
Old Jul 18, 2011 | 06:50 AM
shorod's Avatar
shorod
Also, confirm which engine you have. I'm not aware that there was ever a 3.8L installed in an Explorer from the factory.
As mentioned above, knowing the exact code will help. There are certain codes that point to certain common issues such as manifold gaskets, PCV elbows, and DPFE sensors.
-Rod
bobbydee
1997 - 2003 F150
Oct 21, 2016 02:39 PM
grandpas1974
Apr 8, 2016 11:34 AM
daculpepp
Dec 28, 2013 09:57 PM
norfolknova
Jul 1, 2012 07:18 PM
cjm0269
Sep 20, 2008 11:09 PM
