General Automotive Discussion
Egr Valve Position Sensor Test
Old Apr 13, 2004 | 07:01 AM
guzzler96's Avatar
guzzler96
Question Egr Valve Position Sensor Test
Can anyone out there give me the test procedure for an EGR valve position sensor. This is actually on a '92 Ford Taurus GL 3.8 V6, but I seem to get no response on the car forum. This is a remotely mounted VPS with a three wire plug. It has one vacuum line coming off the EGR to the sensor. I find some ohms readings of 5500 max. and 100 min., but do not know exactly how to check this. Any help would be appreciated.
Thanks,
guzzler96
Old Apr 13, 2004 | 07:07 AM
bigjack's Avatar
bigjack
Get a multi-meter,follow the directions for testing resistance. Place the probes on the contacts. If the Ohms are zero the circuit is open.
Old Apr 13, 2004 | 08:57 AM
guzzler96's Avatar
guzzler96
Question EGR Valve Position Sensor Test
Do you by chance know which of the three contacts you read across?? If the circuit is open, does that mean the sensor is bad??
Thanks,
guzzler96
Old Apr 13, 2004 | 09:05 AM
bigjack's Avatar
bigjack
Try every possible combination, if you don't get the correct reading between any two then it is bad. You could take the multi-meter into the parts store and check a new one to see what the readings are.
Old Apr 13, 2004 | 07:08 PM
guzzler96's Avatar
guzzler96
Thumbs up EGR VPS test
Thanks for the help. I think I will buy a VPS and take some readings off of it and compare them to the one on the car. As long as I don't put it on I can take back.
Old Apr 14, 2004 | 05:17 AM
bigjack's Avatar
bigjack
Most parts stores will not accept returns on electronic modules. Better ask first.
Motorhead351
WTB - Parts & other
Apr 7, 2016 05:39 PM
casanova76
1997 - 2003 F150
Mar 15, 2015 07:21 PM
BrianLaverty
Jul 12, 2013 12:02 AM
camccardell
Computer Chips & Tuners
Mar 29, 2008 10:06 PM
wook540
Apr 4, 2007 09:55 AM
