Sponsored by: Auxito
dpfe??
Old Mar 13, 2015 | 09:48 PM
casanova76's Avatar
casanova76
dpfe??
Stumbles on cruise, changed egr valve and tps sensor, should I change dpfe sensor next ?
Old Mar 14, 2015 | 07:09 AM
projectSHO89's Avatar
projectSHO89
Why are you randomly changing parts without any data that indicates they are defective?
BTW, we are not psychic. You have to provide useful details.
Old Mar 14, 2015 | 09:41 AM
Bluegrass 7's Avatar
Bluegrass 7
Mass changing of parts trying to guess is not the way.
What year and motor?
Are there any codes set or CEL light?
Good luck.
Old Mar 14, 2015 | 10:33 AM
casanova76's Avatar
casanova76
I got a code of po401 says exhaust gas recirculation insufficient detected, the truck is a Ford f150 4.6
Old Mar 14, 2015 | 07:06 PM
iamvandemon's Avatar
iamvandemon
I'm not as smart as project and blue.
What is the year and transmission. And what in the world are you talking about?? The truck stumbles when using cruse control? or while cruising and at what RPM and speeds?
Old Mar 14, 2015 | 10:29 PM
casanova76's Avatar
casanova76
The truck is a 2001 f150 it stumbles after I speed up on highway going at a steady pace, it jerks , but when I press gas pedal to speed up it stops as soon as I reach my speed I softly ease off pedal n it begins to jerk or stumble..
Old Mar 14, 2015 | 10:59 PM
Bluegrass 7
Ok. I just wanted you to come to this point and learn it's important to be accurate before I said the following..
NOW, you have a 99% chance it is one bad coil.
To find out which one, use a Scanner to look at mode 6, test 53 (as Ford calls it).
This is the 8 individual cylinder misfire monitors.
The one/s with the counts out of limits is/are your trouble.
Replace the coil.
Good luck.
Old Mar 15, 2015 | 04:39 PM
casanova76's Avatar
casanova76
Ok I got a chance to go to AutoZone today.got the coil swapped it out. Took for a test drive, seems to be doing better, no stumbling or jerking, I put diagnostic on it because cel still on n it's still giving me same codes..
Old Mar 15, 2015 | 07:21 PM
Bluegrass 7
What coil did you ID as a fault?
The faulty coil for this type of drivability normally sets no code.
It has to be found by looking at the misfire monitors.
There is a explanation behind why it sets no code.
Good luck.
blieux1
1997 - 2003 F150
Feb 24, 2007 08:55 AM
merritdc
Jun 26, 2004 08:02 PM
tomf52
1983 - 2012 Ranger & B-Series
Jun 13, 2004 09:34 PM
bufordt
Dec 10, 2001 11:32 PM
