Rotella
Old Nov 23, 2002 | 09:49 PM
Starratt04's Avatar
Starratt04
Rotella
I use Motorcraft oil from Wal-Mart its made buy Ford so its good isent it?
99 F-250 S/C 4x4 PSD Lariat Diablo Delta Chip
99 Mustang Cobra 4.56 gears, power pullies, short shifter, timing adjuster, Flowmaster exhaust not cat's
Old Nov 24, 2002 | 05:45 PM
dumontkid's Avatar
dumontkid
Rotella
[updated:LAST EDITED ON 24-Nov-02 AT 06:46 PM (EST)]Shell also makes a superior aircraft engine oil. i use shell in both of my rigs and airplane!
96' F-250SC
79' Grumman American Ag-Cat 600hp
76' F-250 Hi-Boy
Old Nov 24, 2002 | 07:12 PM
89greyghost's Avatar
89greyghost
Rotella
i use kendall super d in my 7.3 n/a with a psd filter.i also use it in my 77 f250 w 351 works great good price 5 gallons for 27.00 with tax
Old Nov 25, 2002 | 01:00 PM
Oneof6's Avatar
Oneof6
Rotella
Rotella-T is what I use, many do. The important thing is to keep it clean by changing often and use the correct grade. If you do that it probably doesn't make much difference. Some like me get oil at Wall-Mart. The reason I do is not to squabble over a few cents but is disposal. I get my oil at Wall-Mart and take the old oil back next trip. They let me dump the used oil into their waste oil tank in the automotive service bay. I don't even have to buy it there, but fair is fair. I appreciate them being so pleasant about taking the old oil in.
Regards
Old Nov 25, 2002 | 03:43 PM
jimandmandy's Avatar
jimandmandy
Post Rotella
>good isent it?
As long as it is the correct grade. I have never seen the 15W-40 Motorcraft oil at Wally's. The 5W-30 or whatever is not the right stuff for the PSD. Motorcraft oil is made for Ford, not by Ford anyway. Delo, Delvac or Rotella, you can't go wrong with those.
Jim
Old Nov 26, 2002 | 01:33 PM
Sam Wactor's Avatar
Sam Wactor
Rotella
[updated:LAST EDITED ON 26-Nov-02 AT 02:37 PM (EST)]I'm a senior offshore production mechanic. We have been using Rotella in our industrial engines for years. Of course we don't use a multi grade. We mostly use plain 40 Wt. We change the oil in our engines at 720 Hrs plus we do oil analysis at each oil change and in between if we suspect a problem. At one time we even went to a 1500 Hr oil change in our engines that were light to medium loaded. Anyway our engines look like new on the inside when inspections are done. There is never any sludge build up with the Rotella oil. Wear always appears to be normal. Some of our gas compressor packages (many powered with Waukesha V-12 7042 GSI engines, some with Cat 3600 series engines,) are leased from third party companies. With these packages most third party companies send their own mechanics out to do major inspections such as quarterly, semi-annual or annuals. I've heard many time after the inspection was complete that how clean the engine was internally.
I've been a senior mechanic in the Gulf of Mexico for 20 years and I can not think of one engine failure related to Rotella oil. Altho we have not always used Rotella. Once we used Delvac oil. (I'm not going to mention the manuafacture name) We did have some engine failures related to this oil.
This is one of the things that sold me on using Rotella oil in my PSDs.
Old Nov 26, 2002 | 05:27 PM
jimandmandy
Post Rotella
>96' F-250SC
>76' F-250 Hi-Boy
How much Aeroshell Grade 120 does that radial engine burn per hour?
Jim
Old Nov 26, 2002 | 08:58 PM
haakeye50's Avatar
haakeye50
Rotella
Old Nov 28, 2002 | 02:24 PM
GeeBee's Avatar
GeeBee
Rotella
[updated:LAST EDITED ON 28-Nov-02 AT 03:25 PM (EST)]Radial engine oil consumption rate is easy, take the fuel flow and multiply by 2.
Mike F250
Sep 18, 2021 01:40 AM
TheDuke
Apr 28, 2009 08:43 AM
triskit16
Mar 12, 2009 12:08 PM
kawika
Dec 28, 2004 09:55 PM
