Rear wiper
Old Apr 12, 2004 | 11:05 AM
jwirth's Avatar
jwirth
Rear wiper
I searched and came up with zilch.
My question is what to do about the rear wiper that doesn't wipe well. It appears to have no tension on the blade to contact window with.
Any suggestions?
Thanks.
Old Apr 12, 2004 | 11:11 AM
99Xplr's Avatar
99Xplr
Bend the arm... that is what I did.
Old Apr 12, 2004 | 12:15 PM
jwirth's Avatar
jwirth
Do you have to detach it from the shaft first? Otherwise you are bending into the door.
Old Apr 12, 2004 | 12:25 PM
99Xplr's Avatar
99Xplr
I didn't detach it. I just pulled it away from the door, bent the arm a little and tested.... eventually I got it so it worked pretty good.
Old Apr 12, 2004 | 01:11 PM
nhfire 77's Avatar
nhfire 77
I did the same thing that 99Xplr did. It took a few tries to get it right and after a few automatic car washes it needed a 2nd adjustment-but it works well just play with it(the arm that is)
Old Apr 12, 2004 | 10:31 PM
e-manfive's Avatar
e-manfive
i have 95 xlt,had same prob,had a lip/nub on back of wiper arm blocking full blade pivot,tried bending arm,arm didnt clear window handel,so i bent the arm back,cut off nub/lip off arm with a jigsaw,got a little tighter spring from the hardware store,put it on myself,works great now! you will need to take off wiper blade & arm to do the fix,good luck.
Old Apr 13, 2004 | 07:02 AM
jwirth's Avatar
jwirth
Sounds like what I need to do.
Thanks.
Old Apr 13, 2004 | 10:28 AM
Maximrider's Avatar
Maximrider
There is a service bulletin for the rear wiper. The number is 15406. I had my 99' in for this although it still isn't fixed....... bending the blade may be a good alternative...
Old Apr 13, 2004 | 12:17 PM
jwirth's Avatar
jwirth
Do they do these free on a '94?
Old May 8, 2004 | 11:55 PM
Huffer's Avatar
Huffer
Had to remove inside panal and bend mounting bracket to make wiper shaft perpendicular to the window through entire sweep. The bracket is flimsy and rubber mounted. If you stand behind vehicle and look at the shaft it is probably angled down and to the left. With wiper running,push the shaft up and a little to the right and see if it makes fuller contact with the glass. Too much tension on the arm just made mine hang up in the gap between the glass and the door panel. One trip through the car wash can screw it up again!
Huffer
Old May 11, 2004 | 05:07 PM
Phantom2's Avatar
Phantom2
Don't even bother trying to bend the wiper arm.You can pick up a new for about $13 from a ford dealer.
usz
18
Feb 20, 2018 04:10 PM
Wilmax
Mar 30, 2014 05:55 PM
greenterror
Jan 9, 2009 03:33 PM
Maddog521
Escape & Escape Hybrid
Aug 25, 2008 09:23 AM
blackbear
Jul 21, 2008 02:03 PM
