PSD Down Again
Old Apr 11, 2004 | 07:36 PM
SimCity's Avatar
SimCity
PSD Down Again
I have had my Ford PSD now since Aug. 03 and Nov. 03 the CPS went out. Towed it to Ford and paid the 100.00 deductible. Now its dead again in the employee parking lot at my work. Exact same thing. Crank, Crank, no tack movement, no start. Can it really be possible that the CPS is out again. I cant have a truck that is not dependable. Is this going to be a regular thing.
Old Apr 11, 2004 | 08:28 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
It sounds like the CPS, unless I'm just sadly mistaken. From what I vaguely remember, too much moisture is what kills it. You could easily replace the CPS yourself, it's a relatively easy fix to a sometimes common problem. There are alot of threads on this, do a search and you'll find what you need to fix it. Unless you're under warranty, I'd fix it myself. Don't buy the part from your dealership, you'll get ripped off. If you buy from an International dealership, you'll save yourself about $100. It's about $88 give or take.
Old Apr 11, 2004 | 08:31 PM
johnsdiesel's Avatar
johnsdiesel
Have you washed the engine recently or been in water?
terrylamar
40
Jan 21, 2014 08:46 AM
barkmulcher
23
Sep 2, 2011 01:14 PM
seanj5202
May 27, 2011 09:49 AM
scatgo
33
Feb 4, 2010 12:13 PM
lakerats
Jun 2, 2008 10:54 AM
