Losing antifreeze
Old Apr 8, 2004 | 10:24 AM
rtbktr's Avatar
rtbktr
Losing antifreeze
The last few times that I have change the oil in my 99 4.0 I have had to add not quite a half gallon of antifreeze. The oil looks clean cannot find any leaks or smell antifreeze inside or out. Any ideas? Thanks
Old Apr 8, 2004 | 10:48 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Pressure check your cooling system with a tester. It is going somewhere. Radiator shops will sometimes do this for free, hoping there is a leak in the core they can fix.
Old Apr 8, 2004 | 01:33 PM
rtbktr's Avatar
rtbktr
Thanks I bought a new cap to try if that does not help I will have it tested.
Old Apr 8, 2004 | 03:05 PM
Ken00's Avatar
Ken00
The 4.0s are known for leaking a little at the intake manifold. Rockledge should have more info on this topic.
Old Apr 8, 2004 | 04:22 PM
Rockledge's Avatar
Rockledge
Yes, several months ago I was also losing some coolant, but it happened during the summer, and I too saw none of the usual signs of abnormal coolant usage, so I didn't think much of it when I was replenishing the overflow bottle. The truck was (and still is) running great, things seemed normal. Then, just for the heck of it, I had an oil analysis done which indicated that my 4.0L had traces of coolant in the oil.
After my inital surprise, I looked into the issue a little bit and bounced it off a few knowledgeable people. Turns out that the 4.0L can have some problems with lower intake bolts loosening up and/or the lower intake gasket breaking down. (This can also cause air leaks and lean conditions). After considering all possible causes, I honed on this one, as it made the most sense.
So I re-torqued the lower intake bolts (5 of the 6 needed some torquing, a couple of them were way off) and then performed a cooling system pressure test (and radiator cap test) which showed no leak down. Sometime after that I performed a compression test, and all the cylinders were within specs.
So I think I'm good to go. But I will be having another oil analysis done later this spring, and if my oil still has traces of coolant in it, then I'm going to tear into my 4.0L a little and replace some gaskets.
Old Apr 12, 2004 | 05:28 AM
fixingbus's Avatar
fixingbus
Just had to take my 98 in for a intake gasket (Antifreese leak). It used some coolant for the past 6 months. I pressure tested and no leak down. Luckly I was driving when it went, it really leaked out the left rear corner of the intake. So if your using coolant really check it out.
1'stonraceday
1978 - 1996 Big Bronco
Dec 2, 2014 11:44 PM
1'stonraceday
Dec 2, 2014 05:40 AM
Mr. Bob
Dec 4, 2006 09:58 AM
jimkidd
52
Dec 10, 2005 07:03 PM
88grandmarquis
Sep 24, 2003 11:05 PM
