Interior Rain Leak
Old Apr 7, 2004 | 04:16 PM
jdr567's Avatar
jdr567
Interior Rain Leak
I have a 1994 Ranger XLT Extened Cab. Rain/water leaks into the interior on the passenger side. Seems like the water drain that drains the area under the fresh air vents on that side is plugged causing a over flow bypassing seals and into the truck. Problem is the cover is tack welded down and I can't access that area. Can I easily remove the cover if I break the tack welds? How else can I clear the passenger side drain?
Thanks
Old Apr 7, 2004 | 08:13 PM
Dealford's Avatar
Dealford
Welcome to FTE jdr567.
Now that you've looked at it, does it look like you could get in there with a custom nozzle and compressed air?
Old Apr 8, 2004 | 06:48 PM
jdr567's Avatar
jdr567
Maybe, I would have to buy one or have one made up. Visibility is also poor. I was wondering if the vent body will just lift off if I grind of the tack welds. I can tack it back on if it works. Thanks for the idea
flyboys101
16
May 5, 2021 05:11 PM
cityjack
Dec 31, 2015 08:48 PM
Demonhawk
18
Nov 13, 2015 08:58 PM
Under Pressure
Mar 21, 2014 01:59 PM
Castaic Lion
Dec 28, 2008 01:25 PM
