hard starting 7.3L
Old Dec 13, 2009 | 11:43 AM
JOSH92F-250's Avatar
JOSH92F-250
hey guy i got a 92 f-250 with 240,000 + and yesterday its was getting harder and harder to start it will crank im getting fuel to the filter and weird thing is if i get a pull and pop the clutch she fires right up i have had the block heater pluged in all night and it wont start this morning no smoke coming out the pipes so my guess is im haveing trouble getting fuel its raining here right now so i can work on it till i get a pull start and drive her down to my buddy's house any help would be great thank ya'll
Old Dec 13, 2009 | 12:02 PM
starmilt's Avatar
starmilt
Usually if it is return lines it will start, then die then be hard to start again in decent weather. It sounds like you have a glow plug problem, possibly a fuel return problem too.
There is a fuel heater too it is in the top of the fuel filter header on the 7.3's and in the fuel line between the pump and the fuel filter on the 6.9's.
The diesel could also be a problem if your not running a fuel antigel additive depending on how cold it is and what blend your supplier has.
Old Dec 13, 2009 | 12:39 PM
JOSH92F-250
thanks for the reply man ok so if i take a test light to the glow plugs do i need to pull them out or can the stay in ive heard that on the 7.3 the glow plugs could break off trying to take them out also this truck came for neworlands la to exmore va this will be its first real winter and its starting to get cool like 28 f in the morning but i went out there an gain this morning she fired up ran great and no wont even give me smoke wile cranking so thank u and i would appreciate any more help yall could give me
Old Dec 13, 2009 | 01:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Josh92F-250,
Welcome to FTE and the IDI diesel forum.
So it did start this morning?
Old Dec 13, 2009 | 01:55 PM
JOSH92F-250
yea but it wont start now ive heard no to use starting fluid what do yall think on that and where is the fss is it behind the air filter
Old Dec 13, 2009 | 02:24 PM
Dave Sponaugle
I think you have a glow plug problem.
The fuel shut off solenoid is inside the IP, back wire drivers side.
With the key on, if you remove and install the wire, in a quiet place you should hear a faint click as it opens and closes.
If the FSS was not working, it would not run when you pulled it.
Also what condition are the batteries in?
Cold weather makes what was a marginal battery in warm climates so much excess weight to carry around.
So I would also have the batteries load tested.
If you do that, most auto parts stores will test them for free, but just make sure you unhook the ground wire from one battery so you can test them one at a time.
Otherwise the test is useless.
Old Dec 13, 2009 | 03:01 PM
JOSH92F-250
1 battery is 3 4 months old the other is 2 months and onces shes warm shell run how do i do i test my glow plugs and what would be the best brand to buy and i dont want to buy some pos made in china junk
Polkster
Mar 31, 2014 09:35 AM
bassin88
Oct 11, 2009 07:50 AM
signguys
46
Jan 11, 2007 07:23 AM
PA Fifth Wheeler
Electrical Systems/Wiring
Mar 31, 2003 07:35 PM
