Sponsored by: Real Truck
idling rough 7.3
Old Oct 10, 2009 | 11:37 PM
bassin88's Avatar
bassin88
Question idling rough 7.3
i have a 2000 psd it has started running rough on idle it fine when you first crank it up then it seems as it warms up thats when the rough idle starts if any one can help thank you
Old Oct 11, 2009 | 07:50 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
How clean is your oil? How familiar are you with the sensors on the 7.3 PSD? There are 2 that I'd "look at" first...
ICP - Injection Control Pressure sensor, on the front edge of the driver's side cylinder head. While the truck is off, unplug the harness from the sensor. this will force the ECU to use default values and not readings from the sensor. If she smooths out, get a new one.
IPR - Injection Pressure Regulator, on the back of your HPOP. Not likely to be this one, but depending on mileage and the condition of your oil, it could be sticking.
Neither sensor is cheap ($200 ish each) but Ed (www.partsguyed.com) has REALLY saved my bacon and got me parts ASAP & for a great price.
Also, you might ask the Moderators to move this thread to the 7.3 PSD forum.
b.hope014
1997 - 2003 F150
May 4, 2017 01:02 PM
thefox48
1997 - 2003 F150
Nov 4, 2015 01:12 PM
MentalState
Apr 10, 2014 11:34 AM
btdrygulch
1983 - 2012 Ranger & B-Series
24
Oct 11, 2010 01:46 PM
leonard600
Sep 2, 2010 02:55 PM
