Warm up a 7.3 ?
Old Mar 31, 2014 | 08:02 AM
Polkster's Avatar
Polkster
Warm up a 7.3 ?
7.3 has started running real rough, coughing and spitting like its fuel starved. Runs fine when 1st cranks up, just when try to take off before it warms up will it go thru its spasams.
Stop the motor and crank it back up its still a little rough but will eventually smooth out and run fine. After its warmed up.
I live in a warm climate, it happened yesterday in the middle of a 70 degree day.
I usually let motor warm up for a minute or 2 before taking off but it seems to take a good 4 to 5 mins now.
Fuel system?
Battery voltage?
Old Mar 31, 2014 | 08:32 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I would look to the fuel system. Start with checking fuel pressure. Is it a new filters? Could be a dying pump. Does it do it when you put it into gear?
Old Mar 31, 2014 | 09:03 AM
Polkster's Avatar
Polkster
Yes it runs fine at start up, coughs and sputters when put it in gear. I have plans of changing fuel filter. Cant get to it until thursday tho.
Old Mar 31, 2014 | 09:23 AM
HKusp's Avatar
HKusp
It could also be a glow plug issue. I know you said 70 degree day and all that, but the glow plugs do play a part in warming the engine, even at those temps. Have you checked the relay to see if it is providing voltage?
Old Mar 31, 2014 | 09:35 AM
Polkster's Avatar
Polkster
I've read that also, said check ohms on it? What kinda of voltage should I have?
I'll check the tech folder and see what it says.
Thanks
Jerrodt25
26
Jul 27, 2016 03:47 AM
Shiner527
Dec 21, 2013 06:19 PM
Jakesrodshop
16
Mar 25, 2009 10:35 PM
94F250_weekender
Jun 14, 2007 05:48 PM
Jake331
Mar 29, 2007 04:36 PM
