410 getting hot
Old Apr 7, 2004 | 07:47 PM
Thomsen's Avatar
Thomsen
Yeah i raced last year too...70 highboy with 4'' lift 38.5 boggers...raced in big block modified. I have a built 466 instead of the old stock 360 for this year though...hehehe
Old Apr 7, 2004 | 07:50 PM
mudracin74's Avatar
mudracin74
Oh I know what your runnin. Did Wade Burres ever talk to you about your tires
Old Apr 7, 2004 | 08:51 PM
Thomsen's Avatar
Thomsen
Yeah I talked to him about em but he never called me back...
Old Apr 7, 2004 | 10:07 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Kurt...
I went to the ford dealer ..Like a Dummy..and paid way to much for mine...but I have to have it..for a speedadrome run for my A/EA 48 fiat....but you can find them at the bone yard or have someone build one for you!!-Russ
Old Apr 7, 2004 | 10:10 PM
rusty70f100's Avatar
rusty70f100
I didn't know they put a stock 4-core radiator in 'em. Guess I never looked. I may take a trip tomorrow, thanks for the heads up on that one.
Old Apr 7, 2004 | 10:23 PM
RapidRuss's Avatar
RapidRuss
You betcha Kurt! -Russ
Old Apr 8, 2004 | 08:43 AM
FERacing66's Avatar
FERacing66
i would reccomend getting a fan shorud for your new 4-core. this will help airflow a lot amd will improve cooling even more.
Old Apr 8, 2004 | 12:41 PM
scroob's Avatar
scroob
Putting an electric fan in front of the radiator that already has the factory fan will act as nothing more than a baffle and will actually decrease the airflow through the radiator. It can't even come close to matching the CFM pulled by the stock fan, let alone add to it.
Since you are high revving the engine anyway, airflow through the radiator should not be a problem. As mentioned, if you have no shroud, by all means get one. The shroud is a vital part of the cooling system, and is too often discarded by shadetree mechanics.
I would also recommend a 4 row radiator.
An alternative would be a PROPERLY installed electric fan system. By this, I mean heavy duty. high CFM double fans with the proper radiator shroud, not an Autozone cheapo held on with zip ties. The advantage here would be that the fans will keep cooling even when you throttle down.
Falcon Guy
Apr 7, 2009 03:51 PM
OrangeJuice
18
Feb 17, 2008 12:33 PM
big_i80
Dec 16, 2007 04:12 PM
robertbourque
May 2, 2007 06:12 PM
mudracin74
Engine Swaps
Jun 23, 2004 07:40 PM
